Old 03-14-2012, 06:27 PM   #15
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Whatever type of seal at the bottom of the toilet bowl, it should seal well enough to hold water. Leaving some water at the bottom of the bowl will insure that no black tank gasses are coming back into the trailer from the black tank. If they are, there should be bubbles in the water at the bottom of the bowl.
If your gray tank valve is left open, and there is no "U" in the slinky hose, gasses can come in from your sewer connection unless you shut the gate valve on your gray tank. Even with that valve open, the "P" traps, if they have water in them, should keep odor out.
We have never had that problem either in our Caravel or our Excella.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 06-11-2012, 01:34 PM   #16
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Angry Mystery Black tank odor
Thanks Jim .... I did find that when the a/c was on high for some time there was a negative pressure in the stream. If I hit the pedal it would immediately pull in sewer gas into the a/c and blow it front to back from the a/c, no smells anywhere else (closet, under a/c, bathroom).There must be a way it's pulling from the exhaust vent pipe, since I added a 2 foot extension and the problem stopped immediately (can't drive down the road that way). For the naysayers, it's hard to argue it can't happen, standing there with the a/c blowing in my face, flush the toilet and instant stink coming from the a/c , not from the toilet or bath area, and I mean instant, like a shot out of a cannon. If I shut off the a/c and flush nothing smells, wait 3 minutes and start the a/c up again and clear air.
arcamedies is offline   Reply With Quote
Old 06-11-2012, 04:20 PM   #17
rogerdodger's Avatar
Fresno/Clovis , California
Just a wild guess, maybe you have a leak in the vent pipe in the small "attic" space between ceiling and roof. A/C may be pulling from vent in the same area? Or the bad gasket on the vent allows fumes to go into this space above ceiling.?
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 06-11-2012, 04:24 PM   #18
Also, if you think the wind is causing this, maybe you could try parking the trailer in another space with the wind from the front? I had a sob motorhome that would pull fumes into it from a vent pipe close to the bath ceiling vent. The fix was a gadget on the vent pipe that turned with the wind so vent fumes could not go into skylight vent.
Roger
Air# 29488
Old 06-11-2012, 08:55 PM   #19
1988 32' Excella
Robbinsville , New Jersey
Actually that gadget made it so the wind could not blow into the tank to pressurize it.
Sounds like you need to check that sewer vent pipe cover gasket.
Close to or even with the top of the vent should be right if you have the same type of vent that is on my trailer, the vent is only about 3" high on mine.
Need help with Interior End Caps Davis Upholstery, Blinds, Walls & Interior Finishes 11 04-06-2012 06:25 PM
Gas tank 1/4 full on bifuel generators?! Toller Generators & Solar Power 4 03-11-2012 08:05 PM
Need Help Deciding on Airstream Smith77494 Dollars & Cents 18 03-09-2012 06:10 AM
Help towing an Airstream Safari from AZ to CA drmittens On The Road... 4 03-08-2012 11:45 PM
1982 silver streak continental supreme 35 foot travel trailer vintage airstream eBay Watch Airstreams on eBay 0 03-08-2012 06:00 PM
