Old 12-01-2015, 12:35 PM   #1
1973 31' Sovereign
Sumiton , Alabama
Black Tank Fittings
Moving forward on my 1973 land yacht and final order tanks today a gray and black. The tanks are abs plastic and has the 3" dump fittings and probes but I will need to add the toilet and vent as well as a vent and inlet for the gray. Any suggestions on how to glue the fittings to the tanks? I've not been able to find a rv shop the spin fits as yet but thought I read a forum here about using a glue but not been able to get back to it. Suggestions please?
mingle51 is offline   Reply With Quote
Old 12-31-2015, 11:23 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Many are now using the rubber grommet method. I Order new tanks too and this is the method they suggest. Cut the hole to proper size, install fitting and add pipe. Simple is good 😄
Matt
rugjenkins is offline   Reply With Quote
Old 12-31-2015, 11:28 PM   #3
rugjenkins's Avatar
1975 Argosy 28
For your project no need to spin weld- glue with abs cement. Quick and easy. My tanks are poly and nothing will glue that's why they use grommets or spin weld. I like the grommets better. Abs is the easiest to work with- glue and through.
Matt
Copper compression fittings vs. flare fittings phippsto LP Gas, Piping, Tanks & Regulators 37 12-07-2015 03:08 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
What are the modern/standard fittings for fresh and black tanks? josephpearce Fresh Water Systems 2 02-22-2009 03:48 PM
Polyethylene tank fittings Zeppelinium Fresh Water Systems 1 01-31-2008 10:53 AM
Sealant for holding tank & dump fittings? wayner1239 Waste Systems, Tanks & Totes 8 04-06-2006 06:58 PM
