Old 03-08-2015, 02:06 PM   #1
1986 25' Sovereign
Cincinnati , Ohio
Black and Grey Tank Valves Hard to Pull
Hi there...
Just got our '86 Sovereign 25' and it is up at Jackson Center getting serviced. I had a concern with the black and grey tank valve that I reported to the technician. It is very hard pulling on the valve to let the water drain from the black and grey tanks and I was worried I would bust it.
The estimate to fix it is with a "all plastic slide-EZvalve repair kit". The cost for the kit is $51.34. That would be okay but the problem is the AS service center estimates that it would take 5 hours to "rebuild both great and black tank valves" at $100+ an hour. Has anyone ever fixed this problem. What needs to be done and how hard is it to do? Any advice would be helpful before we advise the factory on whether to move on this. Thanks.
Ssmookler is offline   Reply With Quote
Old 03-08-2015, 02:35 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The hardest part of servicing (or replacing) the dump valves is usually getting to them. Some AS models have the valves exposed so replacement is usually straightforward. Other models have their dump valves buried behind some metal panels. If you have the latter (and I suspect you do since you are asking this question) take a look at this area to see if you feel comfortable opening up the metal panels to access the valves so you can replace them yourself. Some people will just cut an opening or two in the panel to get at the valves and then rivet a new access panel over the hole(s) they made. It might be easy enough to drop the entire panel and keep it intact so you can just rivet it back in place when you've replaced the valves.
Bob Martel
WBCCI# 5766
Old 03-08-2015, 04:22 PM   #3
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . OR buy 2 of these & go on with your life. . .
3" twist on waste valve. Mess free valve repair!
Price: $29.98 $22.97
regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
Minuet Water Valves - What is What? Grey and Black ply5013 Waste Systems, Tanks & Totes 1 11-16-2012 11:04 AM
Black/Grey Water Valves - Drama on the road!!! AndyPenny Waste Systems, Tanks & Totes 1 07-19-2008 11:03 PM
'78 20' Minuet repair question: grey/black water drain valves Van All Argosy Trailers 4 01-06-2004 09:40 AM
