Best Repair Solution?
I purchased my first Airstream, a 72' safari. It has been sitting at a freinds ranch since 1999. I filled it with some water and fired up the pump. I discovered a water leak almost immediatly coming from the copper pipes in the back. It apears that the leak is coming from the lines that run across from the water heater side to the shower connection, right in the center of the doorway in the middle of the trailer, under the shower enclosure. Any thoughts to aide in repair is appreciated.
