Old 11-11-2008, 07:23 AM   #1
Send a message via Yahoo to dhe9
bathroom sink won't drain
good morning,
my '03 bambi bathroom sink will not drain. nothing put in there but tooth paste, whiskers and water. any ideas of the cause or how to repair?
thank you,
david
socal
'03 19' bambi
2011 CTD DIESEL
SEMPER FI
RETIRED USMC
dhe9 is offline   Reply With Quote
Old 11-11-2008, 08:15 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
You most likely have plastic drain plumbing. Remove the bottom section of the trap and see if it is clear. If the trap is clear remove the stopper from the sink and check the piping down to the trap. Thing often hang up on the stopper mechanism.
If both are clear reinstall the trap and try putting a garden hose in the vent and make sure the vent is clear by flushing it with the hose. If the vent take water, about a gallon, should prove it is clear.
2004 Excursion 4x4
Old 11-11-2008, 10:13 AM   #3
cammur's Avatar
Roseville , California
Don't forget to try an old-fashioned basin plunger, it may clear a clog. And try very hot (not boiling) water. Hardware stores also have a low cost plastic item that works great for clearing hair and similiar clogs from small drains.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 11-11-2008, 10:19 AM   #4
ScottW's Avatar
Hernando , Mississippi
After you do all that is necessary to get things flowing again, I'd suggest getting an inexpensive electric razor or switch to a shaving gel for use in your trailer. I did. Most plumbers will tell you that shaving cream is the worst thing you can put down a drain. As a matter of fact, when my son attended Army basic training two years ago, the recruits were told NOT to bring shaving cream with them, but to bring a gel. I'm not a chemist, but there must be a difference, even the army can't stand clogged drains
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
fixing a 71 kitchen sink drain Lumatic Sinks, Showers & Toilets 3 07-10-2008 08:44 PM
Bathroom Sink grovelander Cabinets, Counter Tops & Furnishings 2 10-20-2007 06:40 PM
'62 Bambi - Bathroom sink drain dudebb 1961 - 1963 Bambi 3 06-04-2007 07:57 PM
Bathroom Sink Lee Pace Sinks, Showers & Toilets 1 08-20-2006 10:51 PM
Sink Drain Leaks ozarkray Plumbing - Systems & Fixtures 0 02-09-2006 09:28 AM
