Old 07-21-2016, 05:26 PM   #1
1970 27' Overlander
Plaquemine , Louisiana
Bathroom faucets.
I have a 1970 overlander. The shower has hot water only . The other sink faucet worked good and now only a small stream when turned on. Do I need to rebuild faucet (cartridge) in shower? Unplug or replace sink faucet? Do I need to check the water pump? I'm hooked to city water. Any help appreciated.
Junkman3 is offline   Reply With Quote
Old 07-21-2016, 06:55 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The water pump is not in play when on city water. Other than it may have a bad check valve letting water flow into the fresh water tank.
You should check the screens at each faucet. If you don't have a screen on the shower faucet it should flow freely.
You could have a bad pressure relief or regulator.
Is there any sign of water running out of the bottom of the coach?
Is there a screen on the city water inlet?
Do you have normal flow when using the pump? If so I would expect the pressure regulator or pressure relief.
Old 07-21-2016, 08:14 PM   #3
Mission , Texas
Shower one extreme or the other only usually indicates it wants a new catridge.
Little to no sink faucet flow is usually the aerator screen wants cleaning.
True for both city water hook up and using the fresh water tank and pump.
nrgtrakr is offline   Reply With Quote
bathroom faucets don't work after de-winterizing Steve97365 Fresh Water Systems 3 05-06-2013 12:39 AM
Excellent Moen Faucets Customer Service 85MH325 Sinks, Showers & Toilets 2 04-08-2011 08:26 PM
Water faucets otha1 Sinks, Showers & Toilets 5 08-31-2003 11:05 AM
Can't seem to get H2O from faucets dinoburb Fresh Water Systems 11 08-11-2003 07:56 PM
