Old 02-16-2016, 01:20 PM   #1
1964 19' Globetrotter
Gallatin , Tennessee
Bathroom faucet replacement
I am working on a 1964 Airstream Globe trotter 19'. I need to replace the faucets on the bath sink and bath tub. I am having trouble getting access to replace them. This set up is a rear bath with the sink over the tub on the door side of unit. I have taken the screws out of the top of sink counter but it is stll attached at the wall or something I can not find. Please help with any information on how to gain access.
Thank you for your help
Brian
Elzysrv is offline   Reply With Quote
Old 02-16-2016, 02:51 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
if you can get your hands in under the sink you need a basin wrench to remove and install the faucet without removing the counter top. Worth the expense.
2004 Excursion 4x4
Old 02-17-2016, 07:15 AM   #3
Brian
There is no access. This is the problem. I am in the RV service business and have changed many even on Airstreams. This particular Airstream has a unique counter with no access from the inside of unit or storage compartment in rear. No closets or cabinets to gain access. The only way I see is to split the counter top from the bottom fiberglass surround. I am having trouble accomplishing this.
Old 02-17-2016, 08:28 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
photos?
Alan
Old 02-18-2016, 08:51 AM   #5
I found the hidden screws under the tub in rear compartment. The bottom skirt came right out and off to work I went.
Old 02-18-2016, 10:41 AM   #6
Mission , Texas
Yep ... like that ... our 75 Overlander rear bath wanted new faucets and partial dismantle was necessary.
nrgtrakr is offline   Reply With Quote
Old 04-11-2016, 01:19 AM   #7
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
Just replaced the guts in my Delta faucet bath sink. It was easier than expected with parts from Home Depot.
Glad you found the hidden screws......I went through a similar problem trying to change out the microwave last year. Was almost ready to get the sawzaw and cut everything out till I found those tiny screws.
Mike1997 is offline   Reply With Quote
Bathroom faucet replacement help msasse Sinks, Showers & Toilets 7 02-23-2015 10:01 AM
'72 Ambassador Repair of Furnace and Bathroom Faucet tdveal General Repair Forum 6 02-28-2008 05:16 PM
Bathroom faucet repair / replacement jesus mike Sinks, Showers & Toilets 7 06-08-2007 10:36 PM
Bathroom faucet replacement billwhelan Fresh Water Systems 1 09-20-2004 08:12 PM
Bathroom faucet and toilet stuff Safari Tim Sinks, Showers & Toilets 5 07-07-2004 04:14 PM
