Old 09-22-2016, 02:30 PM   #1
1974 Argosy 26
Joshua Tree , California
Back flow Problem?
I just finished replacing the copper plumbing in my '74 Argosy 26' with PEX. New pump, new bathroom sink, new commode. Turning the pump on I found one leak and fixed it. I left the old pressure regulator and back flow valve(?) in place. Then noticed the pump was pushing water out the hose connection on outside of trailer. Is there I fix for the existing preventor or should I replace the whole shebang? (Sorry photo is upside down.)
StarckMad is offline   Reply With Quote
Old 09-22-2016, 04:34 PM   #2
1979 23' Safari
Wayland , New York
It would likely cost you more to get parts than buy a new one. At least for the regulator. Not likely parts available for check valve, the guts are pressed in when built.
The regulator may be good.
It looks like on the wall side is an inline check valve. Replacing the check valve will stop the back flow. You can put a check valve in further downstream in the inlet line if it's easier to access.
Check Valve / Back Flow Preventer hmsteader Fresh Water Systems 4 01-13-2014 01:43 PM
Here's the problem, what's the diagnosis: propane flow eubank LP Gas, Piping, Tanks & Regulators 23 09-12-2012 09:25 PM
Is there a back flow valve on my water pump? Mrcrowley Fresh Water Systems 5 04-25-2009 11:06 AM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 11:43 AM
Shower Regulator or Back Flow Valve GStephens Fresh Water Systems 19 07-08-2004 10:56 AM
