Old 08-10-2005, 10:07 PM   #1
1963 19' Globetrotter
Orion , Illinois
Are flex lines best?
I am about to start the water heater replacement project on my '63 Globetrotter and am deciding on what to use in making the gas and water line connections. It looks to me that flexible lines are the best way to go but there are a number of options. I will be tying into new PEX water lines and the existing gas line which will need some relocating/modification. Looking for opinions and suggestions. I only want to do it one leak free time.
63air is offline   Reply With Quote
Old 08-10-2005, 10:18 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Send a message via Skype™ to uwe
PEX is semi flexible, and would surely make good supply lines and discharge lines for the new water heater. That's what I am using on my Overlander project. Consider a water heater bypass kit since you are in a cold climate.
For gas supply lines, you can either dupliate your existing setup, modified to fit teh new water heater gas inlet, or use a flexible low pressure LP line, available from many RV stores. Make sure the connection to the main LP supply is outside the trailer, under the belly pan. It's a safety code.
Uwe
www.area63productions.com
uwe is offline   Reply With Quote
new water lines Rob Fresh Water Systems 29 07-11-2006 08:25 PM
Replacing plumbing lines GTracer Fresh Water Systems 1 06-29-2002 11:02 PM
Water lines in '73 Overlander Bryan Fresh Water Systems 8 06-05-2002 11:42 PM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 01:06 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
