Old 04-04-2011, 07:23 PM   #1
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
Anyone work on the No-Fuss Flush?
I have a 05 Safari 30 that we bought new in 06. I religiously clean my tanks and have never left the valves just open if I am connected to full hookups (which is rare as we are boon dockers). Recently the no fuss rinse system just stopped flowing water when connected to a hose. Doing some research some have had trouble with the back flow preventer that is just indoors from the exterior hookup. These fittings are all PEX some with threaded connections so I made a piece that eliminated the vacume breaker/back flow preventer. Still no water flow when connected to 60psi water.
Anyone worked on the spray head? Maybe it is plugged or has a check valve right at it? Curious as to if anyone is familiar with the system, they still use the same one today.
SafariSS is offline   Reply With Quote
Old 04-04-2011, 07:42 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
I had looked into this for a friend not 2 weeks ago as he took his out of storage. His did not flow either. Here is a link I got advice from - maybe it will help you. BTW we filled the tank and added a box of RIDEX septic tank solution (liquid type not dry box) - did the trick.
RV.Net Open Roads Forum: Fifth-Wheels: no fuss flush don't work
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 04-04-2011, 07:55 PM   #3
SafariSS's Avatar
2005 30' Safari
Clancy, how long did your buddies soak? Is Ridex caustic?
Thanks for the suggestion,
Old 04-04-2011, 08:10 PM   #4
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Septic Tank Products: Septic System Products | RID-X
Rid-X (I went by memory on the spelling) is a septic tank additive with bacteria that are just itching to eat solids from waste systems. There are no chemical additives just bacteria. Powder form takes time to activate and had residual solids that in a big home septic tank will not make that big a difference. In the RV - less solids the better so the liquid kind is what we used in his trailer. It made the guages seem to work more accurately too. May just be a fluke but it did work and not that much expense (a tank full of luke warm water and the Rid-X). He let it soak for about three days then dumped. Only thing we could think of was some TP got dried in the valve opening.
BTW - the bugs won't all flush out and will reproduce in the tank for the next "load".
Old 04-06-2011, 02:06 PM   #5
Dan@LED4RV's Avatar
Denton , North Carolina
I've seen soaking with just water do the trick as well.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 04-06-2011, 09:19 PM   #6
SafariSS's Avatar
2005 30' Safari
I picked up some rid-x and filled er up. Will let you guys know how I come out, I am planning a three day weekend this weekend and will drain it then.
Fulltimer Work: Gate Guard slowmover Working on the Road 1 08-06-2011 03:12 PM
Body work needed in TX big dents and tears bendavanza Ribs, Skins & Rivets 6 03-15-2011 08:44 AM
Dealer recommendation for floor work? dryflyfisher Repairing/Replacing Floor &/or Frame 1 02-26-2011 08:49 AM
1984 Airstream 18 foot Wrecked Needs work eBay Watch Airstreams on eBay 0 02-05-2011 09:00 PM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
