Old 04-13-2016, 10:43 AM   #1
1978 31' Sovereign
Botgek , Washington
Advice on new tanks and plumping
Hello,
I have to replace the grey and black tanks in my 78 31' rear bath sovereign. Has anyone had custom made tanks built for the rear bath? the tank replacements I've seen online are pretty simple, in terms of dimensions. My tanks now have a few dimensions, I'm wondering if a simple rectangle tank will work. Any experience you have to share would be appreciated. (pic included of my tanks)
I've also attached a .pdf of how I plan to plump it, any advice on if this looks good would also be great appreciated. There is a picture of where the tanks are and there is a "thing" that is part of the plumping and I have no idea what it is.
Thanks in advance
Ryan
ID:	260635   Click image for larger version
Sirwalshalot is offline   Reply With Quote
Old 04-19-2016, 03:57 PM   #2
1978 31' Sovereign
Botgek , Washington
anyone?
Old 04-20-2016, 10:25 AM   #3
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
The thing is a vent.
Custom tanks are very expensive.
I was going to put in rectangular tanks but after much thought decided that the angled slope on most tanks was need. However, I placed 2 gray tanks. One is a box- it's for the kitchen sink. The other fits inside the rails with a slope.
Your tanks would be small but you know your needs.
Here a pic if what I did.Click image for larger version
Name:	ImageUploadedByAirstream Forums1461169140.717809.jpg
The shot is from front to back. I changed my setup from a rear bath to a center bath. As seen in picture. All my tanks are 27 gallons.
Front tank- 54x16x8- kitchen
Mid tank- shower
Rear tank- black
Hope this helps. I ordered mine from ppl.com but it took a month for me to get it.
Matt
rugjenkins is offline   Reply With Quote
Old 04-20-2016, 10:41 AM   #4
rugjenkins's Avatar
1975 Argosy 28
I noticed the p-traps- have you considered the hepvo valves? They free up a lot of space. No back flow issues and no winterizing and no worries on odor issues from dried p-traps. Plus they self vent- you could remove the vent thingy. Just some advice.
Matt
Old 04-20-2016, 10:44 AM   #5
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
What is wrong with your existing tanks? Are they cracked and leaking?
I have a 77 Sovereign, and my tanks looked just like yours. I cleaned them up, changed the valves, water tested them and they are fine.
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 04-20-2016, 11:13 AM   #6
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Originally Posted by Sirwalshalot View Post
Hello,
Thanks in advance
Ryan
That "thing" looks like an "air admittance valve," which works like a vent but is sort of a "poor man's" solution to your overall venting issues. You really should keep the separate vents for your galley area and black tank. From your drawings it looks like you plan on just one vent over near the shower and bathroom area, and that's a pretty long run from the kitchen sink without a vent.
I replaced my three tanks last summer, and I had a bad experience having them made. I did use the black tank that I was having made, and it matched the original exactly. I ended up buying an Inca fresh water tank (found a good match) and then an Inca black water tank that I used for a gray water tank. I had to get creative in positioning, securing, and sloping them but was able to use the original galvanized belly pans that support and protect them, and now have a gray water tank that hold about 24 gallons. I also utilized the three vents that were originally there.
There's a lot of info on these forums about tanks. I think you will find that unless you have your tanks custom-made you will have to buy "close matches" and then get creative. There are many ways to do it, and many good threads here.
youngpeck is offline   Reply With Quote
Old 06-23-2016, 08:51 AM   #7
RumbleStrip's Avatar
1984 31' Excella
Cottage Grove , Minnesota
Thats encouraging!
We are pulling up floors right now and hoping our tanks are ok!
http://rumblestripramblings.com/
[QUOTE=Sneakinup;1779366]What is wrong with your existing tanks? Are they cracked and leaking?
Meg
Read more about our Airstream, Alice on our blog Rumble Strip Ramblings.
Instagram: @rumblestripramblings
RumbleStrip is offline   Reply With Quote
Replacing water tanks, holding tanks & battery? AussieGirl 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 12:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
Newbie looking for some advice on waste tanks and plumbimg in general. Sairaf Plumbing - Systems & Fixtures 2 07-30-2010 04:49 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
