Old 01-14-2013, 08:00 PM   #1
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Adding Water Pressure Accumulator
Our Airstream has no water pressure accumulator, so I decided to install one. They were on sale at Camping World. Shurflo Accumulator Tank - Hypro-shurflo Llc 182-200 - Fresh Water Pumps - Camping World
Here's why.
When hooked up to shore water, they always have/require an anti-backflow valve at the spigot. This locks water pressure inside the Airstreams plumbing and any expansion, such as when the water heater heats up (the new combo elect/propane heaters are extremely hot), can cause leaks as well as frequent spitting at the water heater pressure release. Opening a faucet with this high pressure behind it is also quite abrupt.
When without hookups, the water pump cycles with even the slightest opening of a faucet or flush. This pressure regulator holds about a liter of water under pressure to mitigate some of this, and generally even out the flow.
I installed it under the bathroom sink by disconnecting the cold water supply line at the faucet and connecting it to the accumulator. I installed a 30" stainless braided 1/2" I.P.S. to I.P.S. connector line to the other side of the accumulator and run that back to the faucet.
The accumulator has a standard Schrader valve that takes up to 125 psi, but the factory charge of 30 psi seems just right.
It's a more pleasant operating water system and little, if any hot water heater noise and spitting.
Old 01-14-2013, 08:23 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I mounted my accumulator next to my water pump with my home made flex hoses. It really made a difference. I guess that you could put it almost anywhere on a cold water line. Maybe I should add another one in my bathroom like yours. [good idea]
ID:	176737   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-14-2013, 08:56 PM   #3
2012 25' FB Flying Cloud
Kirkland , Washington
Hey guys,
Thanks for posting the pictures. I've read a lot of posts on installing these but it's nice to see some examples. I see this as being a mod I will likely do this coming spring and these pics give me some great ideas.
Thanks again,
Ron
ResoRon is offline   Reply With Quote
Old 01-14-2013, 09:08 PM   #4
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I installed one in my Excella, but have not installed one yet in my Tradewind that I have had for 3 years now. I really can't say that I have seen much difference between the two or felt the need to install one in the Tradewind. We usually boondock.
I guess that if you feel like your water pump is cycling too much, that is a good reason to install one. They are fairly inexpensive and easy to install. Both installations look great BTW.
Dan
Old 01-14-2013, 09:14 PM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
It's an item that should be standard equipment.
Note that there are some larger accummulator tanks (like the ones Silver Streak once used).
The new-to-me 1990 has a replacement pump from a few years back. But without the accumulator. Check comments by Lewster (Rv tech) about "smart" water pumps that supposedly don't need an accumulator.
This one looks good to me. Room to mount it, plus larger/better pump is available in combination from SHURFLO (this TT has a clothes washer/dryer plus will have whole house filtration at some point).
Shurflo 2/gl Stainless Model 3400
Old 01-14-2013, 10:23 PM   #6
1994 30' Excella
Mississauga , Ontario
my 94 has one that was factory installed. It is hidden behind kitchen cabinets.
Surprised to hear that so many don't have one.
Al
Al and Jean
TAC ON-3
Old 01-14-2013, 10:25 PM   #7
1994 30' Excella
Also remember that the hot water tank has a head of air in it when you first fill the system. If you don't drain the system once in a while the air gets absorbed in the water and then you will get water dripping out the pressure relief valve from expanding water as it is heated. Then it is time to drain the tank and refill.
Al
Al and Jean
TAC ON-3
Old 01-15-2013, 06:56 AM   #8
Captain Hank's Avatar
2007 27' Safari FB SE
Summerville , South Carolina
I have a 2007 Safari 27' FB. I installed an accumulator on the discharge of my fresh water pump. It did not make much difference in the cycling of the pump. I called the pump manufacturer and they do not recommend an accumulator on my pump. My pump has a pressure control and is a variable speed pump. The manufacturer said it needs a firm discharge head to operate properly. Older pumps without this type of control work better with the accumulator.
So I have a new accumulator if someone needs one.
Captain Hank is offline   Reply With Quote
Old 01-15-2013, 10:45 AM   #9
dkottum's Avatar
'Hank, it should make a difference on cycling of the pump as well as other benefits mentioned in my first post. I wouldn't be without it now that I've used it.
Have you tried adjusting air pressures in the accumulator? It only holds about a liter of water but that is sufficient for many shots of water we commonly use during the day. I am surprised it has not improved the overall operation of your system.
I have also tried to maintain the air bubble in the hot water heater, but most of it goes away quickly. That is especially true since we bought the new trailer with the combo propane/electric water heater which easily and frequently produces steam out the relief valve. Many if not all of us with these combo water heaters are experiencing that "feature".
doug k
Old 01-15-2013, 12:17 PM   #10
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Thanks for the photos!
I have been pondering one of these myself. My pump is mighty noisy and I believe along with some better vibratin isolation and an accumulator it would help quiet things down a bit.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 01-19-2013, 03:30 PM   #11
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Ordered this for my trailer and will install it tomorrow. I'd really like to thank you guys for posting this AND for the great photos. I sometimes feel like a "copycat: for all the mods of done to my new trailer, but every single one I've added has made me a bit more comfortable and most of them SAFER (16" wheels/tires). One add that I made proved really helpful this summer at Gooseberry Falls SP in MN. I'd installed an extra ShurFlo pump in the external compartment for the fridge (which I'd wired into the 12V circuit). With NO hookups, I pumped those 5 gallon water jerrycans into my water tank without having to lift, funnel or anything else. I felt SO smart with this idea -- which I'd read on AirForum. Anyway....thanks, guys!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 01-20-2013, 05:29 PM   #12
BAB
BAB's Avatar
2015 30' Classic
Install took around 30 minutes once I had the right parts. Lots of room to do this in my particular model. Since it's winterized, it'll be a couple of months before I can pressure check. I did check the air pressure and it's right at 30 PSI.
_________________
ProPride 3P
AIR# 58452
Old 01-20-2013, 06:26 PM   #13
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Thanks Doug....
Here's why.
I've been wondering what that thing was under the sink cabinet.
And Hank, looks like I had one and didn't know it.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 01-20-2013, 07:14 PM   #14
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
Tanks (sorry couldn't resist) for posting this!
I was just wondering is such a thing exists after I finally took my water heater off bypass for the first time (I'm a fairly new airstreamer) and seeing the improved flushing of the toilet and other pressure benefits. I then promptly ripped out the water heater and put in a tankless just yesterday. So I am going to add one of these. Maybe I'll try to see if I can get a larger one since I don't also have the water heater tank pressure in the system. Probably a very good thing to add for anyone gong tankless on the water heater.
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
