Old 09-20-2008, 12:09 AM   #1
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
Adding more water tank capacity
I have a 2005 Safari 28W. It has a 39 gallon fresh water tank. I would like to increase my capacity. Is there room for a larger tank or another one? The 28' Classic has 54 gallons. How do they do that? Ron
rp709 is offline   Reply With Quote
Old 09-20-2008, 12:55 AM   #2
_
hi ron
the classic and safari lines have different frames.
the tanks rest inside the frame rails and cross members.
i'm sure it's possible to put a larger (deeper) fresh tank in place of the current tank,
but it will take effort and $$ just to gain 10-15 gallons...
it might be easier to add fresh water capacity in the t.v.
a variety of bladders and auxiliary tanks with pumps are used.
fresh capacity can be 100s of gallons using this approach.
here is just one thread on this topic.
http://www.airforums.com/forums/f382...ers-43800.html
cheers
2air'
Old 09-20-2008, 01:00 AM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
If you have room somewhere you could put in another tank... Inside...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-20-2008, 04:54 PM   #4
mustang's Avatar
1999 27' Safari
Kent , Ohio
When I dry camp I use the blue 5 gal jugs for back up supply.
mustang is offline   Reply With Quote
Old 09-20-2008, 05:18 PM   #5
purman's Avatar
1968 28' Ambassador
Hey mustang, thats what we do too.... And it camp grounds with no hookups we use them to fill our fresh water tank with a big funnel...... works great...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-20-2008, 07:05 PM   #6
What's a rivet?
SilverBreeze's Avatar
2008 23' International CCD
Napa , California
The blue 7 gallons plastic containers are the easiest weight to lift and they have a nice built in filler. We go through one a day for two people, cooking and submarine showers. We usually bring 1 gallon of drinking per day too.
All the best,
Daniel
SilverBreeze is offline   Reply With Quote
Old 09-21-2008, 07:50 AM   #7
mustang's Avatar
1999 27' Safari
Kent , Ohio
HAha thats funny we all do it. I find 2 cooler stacked is just the right hight to fill, or a card table. So I dont have to stand there and hold it.
I also use Blue Jugs with the valve thingy or stem on it.
Old 09-21-2008, 08:43 AM   #8
purman's Avatar
1968 28' Ambassador
Those are the one's I have... Great for filling cups of water and other stuff.... My water fill is in the front.. one of those nice big openings... I just lean the jug up on the propane tank so I don't have to hold it.... Although it does fill pretty quick so holding it is ok sometimes...
WIll have to try the cooler and table trick....
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-21-2008, 01:14 PM   #9
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Ron,
You cheapest route if you want a bigger tank may be to upgrade to a 28 Classic. It is a little wider. I would like to have a larger gray tank. My gray and black are the same size around 40 gallons. I fill up the gray long before the black. This would require some serious re-engineering including cutting a cross member and the firguing out how to re-inforcing the frame. THe having a smaller black tank made say around 20 gallons and a 20 gallon gray tank. a newe 40 gallon grey tank with a new cross connect fitting. very expensive and not really practical.
Michelle TAC MT-0
Sarah, Snowball
adding gray water tank to 65 caravel joqin Waste Systems, Tanks & Totes 16 01-24-2009 05:29 PM
Adding gray water tank to a 1971 25' paul903 Waste Systems, Tanks & Totes 15 07-07-2008 10:44 PM
Adding two batteries to the tongue to increase boondocking capacity hshovic Batteries, Univolts, Converters & Inverters 24 01-09-2008 07:04 PM
Water heater & fresh water capacity ESCAPE POD Water Heaters, Filters & Pumps 5 11-14-2007 05:14 PM
Adding a gray water tank??!! kangol Waste Systems, Tanks & Totes 2 04-21-2004 07:11 PM
