Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 09-23-2016, 09:11 AM   #1
2000 30' Excella
Toledo , Ohio
Accumulator Tank ?
I have a 2000 Excella 30 with dinette and split bath my manual says I have a accumulator tank under the galley sink and I don't see one . My question is do all 30's have one if so where can mine be located ? I have looked all along that side of the trailer and can't find it . Any help out there ?
Thanks Les
woodfox45 is offline   Reply With Quote
Old 09-26-2016, 08:46 AM   #2
2000 30' Excella
Toledo , Ohio
Thanks Les
Well since I have no replies and after more checking I conclude i don't have one
Old 09-26-2016, 08:54 AM   #3
Lakes Region , New Hampshire
Les,
If after you run the pump and it shuts off, you shut it off and then open a cold water faucet, the initial release of just the built up pressure should drop right off, if it doesn't and runs for more than a few seconds then you do have one somewhere.
RandyNH is offline   Reply With Quote
Old 09-26-2016, 09:06 AM   #4
ericpeltier's Avatar
Superior , Colorado
Typically, an accumulator tank will be directly next in line after the pump. If you trace the output from the pump and there's no accumulator tank between the pump output and the first connector like a Tee, then, you most likely do not have one.
Eric
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 09-26-2016, 09:34 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
The test mentioned in post 2 will tell you if you have one. It will only be about the size of a small peanut jar and should have a schrader valve on one end.
If it turns out you don't have one install one.
2004 Excursion 4x4
Old 09-27-2016, 04:47 AM   #6
2000 30' Excella
Toledo , Ohio
I'm planning on installing a Flojet V Flo 5.0 water pump and it doesn't need a accumulator ,also a split bath Airstream like mine doesn't have much room to add things to the plumbing system. Thanks for all the replies .
Les
Old 10-11-2016, 09:04 AM   #7
2000 30' Excella
Toledo , Ohio
Well today getting ready to winterize my Airstream and found my accumulator tank it is behind the micro wave and the rear wall of the cabinet impossible to get to without removing the micro wave and cutting out the rear wall of the cabinet . If I blow out the lines and pump antifreeze in will I be ok or do I need to drain the accumulator tank ? Any ideas ?
Old 10-11-2016, 09:14 AM   #8
HowieE's Avatar
Images: 12
If the tank was install vertical and you blow out the lines it should drain itself.
A very poor location for future service but not a problem now.
2004 Excursion 4x4
Old 10-11-2016, 09:27 AM   #9
2000 30' Excella
Toledo , Ohio
Thanks for the reply I don't know how I will ever be able to add pressure to it without removing Micro wave . Thinking about adding a schrader valve extension hose like used for dual rear wheels .
Les
Old 10-11-2016, 09:45 AM   #10
HowieE's Avatar
Images: 12
It should self pressurize when the pump comes on next spring. There is an air pocket in the accumulator the size of which changes as the system pressure changes.
2004 Excursion 4x4
Old 10-11-2016, 05:04 PM   #11
2000 30' Excella
Toledo , Ohio
Thanks again HowieE . I went to Camping World to buy the valve extensions for dual wheels found a pair and they were $50. walked around in the store and found some in the mark down area for $8.00 with tax . so I hooked it up and ran it under the sink so now I can check the pressure without removing the Microwave .
Les
Anyone added an accumulator tank? jdalrymple Fresh Water Systems 2 11-17-2011 03:26 PM
Accumulator tank Jammer Fresh Water Systems 4 09-24-2010 03:20 PM
Why no accumulator? Roger S Fresh Water Systems 29 08-09-2007 06:30 PM
Accumulator Tank silversled Waste Systems, Tanks & Totes 16 02-01-2007 08:32 PM
ShurFlo Accumulator?!? SilverToy Water Heaters, Filters & Pumps 6 04-19-2005 10:07 PM
