Just returned home with our new purchase (1979 28' Excella mh), a 1,200 mile trip full of "adventure". Now the question, located a leak in the water line in the bath area (center bath). The leak is in a brass T on the floor near the driver side wall. I can see the leak through an access hole in the closet but can't reach the fitting. I am new at this and the only idea I have is cutting an access hole in the wheel well, repairing the leak then patching the hole. I would appreciate ideas on getting to this leak and if my idea is ok, how to patch the hole in the wheel well. I love this motorhome and this Airstream Forum. Thanks in advance for your help. Joe
I had a similar issue when mine was new to me. If you have an access hole in the closet that is for draining the water system for winterizing. I simply drilled out the rivets holding the aluminum shelf in place. I did the repair on the pipe and riveted the shelf back in place. Was quite a simple fix.
You could do it the conventional way and remove the panel that covers the plumbing from the inside.
Simply remove trim vinyl insert and drill out the rivets. Then remove panel. You should be able to access the plumbing from the bathroom.
Everything in an Airstream is subject to dis-assembly and re-assembly. The whole thing was built from the inside. All components of an Airstream interior will fit through the entry door.
__________________ Ken Smillie
My 1994 36' Classic MH is for sale See it in the classifieds
i beg to differ with that last statement. the top of the 2 piece shower assebmly will not fit through the door of a 2000 excella. i tried for hours and there was no way to do it.
Thanks for the help. The access port in the closet is 3+ feet from the leak and the closet is only about 10" wide (I'm a lot more than 10"). The portion of the bath that need to be removed for access is the sink, medicine cabinet section. Is this one piece? Thanks joe
