Old 12-26-2012, 03:47 PM   #1
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Aarrrghhh!
We're in the process of refurbing the interior of our '73 Argosy, and I removed the plastic bathroom sink/counter combination. In order to remove it, I had to cut the hot and cold water supply lines - no big deal as I want to put ss braided supply hoses on, so I thought I could just use a compression fitting to adapt from the 3/8" copper supply line to the braided supply hose, right? I mean, what could go wrong?
Well... it seems the 3/8" copper pipe really isn't 3/8". I can't get a compression fitting on no matter what, including heating the fitting with a torch. Instead of being .375", the supply line actually mic's out at .3758. My local plumbing supply guru thinks that at some point the lines froze and expanded but did not break. Maybe.
So I'm looking for suggestions. Has anyone else run into this? I really don't want to tear the whole thing out and start over with PEX as I think I would have to go all the way back to the main supply.
Here are photos. The first shows the sink prior to removal; the next after removal; the third photo shows the two lines just sitting there, waiting for repair. In the third photo you can see the two supply lines cut off, and just below the cut, taking off to the left are the 3/8" lines that feed the shower. One of the reasons for my hesitation to switch to PEX is that these lines might also be over sized, in which case I would have to replace them too- just digging the hole deeper.
Ideas?
ID:	175270   Click image for larger version
Name:	Bath Sink Out.jpg
Name:	Bath Plumbing.jpg
DryFly is offline   Reply With Quote
Old 12-26-2012, 03:50 PM   #2
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
seems such a short run. not like your local code enforcement it going to be in there but some short runs of flex tube (water grade) and some hose clamps. and a few beers.
Protohyp is offline   Reply With Quote
Old 12-26-2012, 03:56 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
emory paper and a few rubs.
Old 12-26-2012, 04:18 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
According to ASTM B88 "Standard Specification for Seamless Copper Water Tube", nominal 1/4-inch Type K, Type L or Type M copper tubing for water supply service is 3/8 inch outside diameter, with a tolerance of Ī0.002 inches for annealed pipe (suitable for compression fittings; drawn pipe, not suitable for compression fittings has a tolerance of only Ī0.001 inches).
No, that's not a typo; the 3/8-inch outside-diameter copper pipe actually is a nominal 1/4-inch size.
So anyway, if it miked out at 0.3758 outside diameter, it's actually within manufactuing tolerance, since it's between 0.373 and 0.377 inches for annealed pipe, or between 0.374 and 0.376 inches for drawn pipe. No need for it to have expanded due to freezing.
Sorry I can't offer a sugggestion to mate the braided line to the copper tubing; I've never actually done a transition like that. I only know about the ASTM B88 because I've had to deal with it for work.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-26-2012, 05:23 PM   #5
rogerdodger's Avatar
Fresno/Clovis , California
Good answer. Flex tube may outlast the rest of the plumbing.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 12-26-2012, 05:45 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Copper lines once frozen are just a teeny bit bigger.
I thought this was a thread about pirates. Arrghh.
Old 12-26-2012, 06:32 PM   #7
DryFly's Avatar
1972 Argosy 20
Thanks to all. I'm heading out tomorrow and getting flex tube, seems like the easiest thing to do.
Old 12-26-2012, 07:24 PM   #8
Protohyp's Avatar
do you need me to give you the address to mail the beers?
Old 12-26-2012, 07:34 PM   #9
Southwestern , Ohio
Yeah, I've run into this situation more than once. In one case, I'm pretty sure the lines had been frozen a time or two.
There are a couple of alternatives. One time I made a mandrel on the lathe to expand some sweat fittings a little to fit the swollen copper tube. It worked!
You might try Sharkbite fittings (or similar Lowe's Gator Bite) which seal on the OD of the tube with an O-ring and seem to tolerate a little diameter variation.
The flex tube and hose clamp approach will probably work OK. Use two hose clamps at each transition from copper to flex tubing. Double-clamped fittings seem to be a lot more reliable than single-clamped fittings. I don't know why.
Nuvite-F is offline   Reply With Quote
Old 12-26-2012, 07:42 PM   #10
1974 Argosy 20
Kooskia , Idaho
That problem happens all the time and I have run into it too. Simple, once you understand what happened. At some point the lines froze and expanded. Now they are no longer the original diameter and you cannot get the compression rings on them. If you try to flare them, generally the flare will not work either, as the metal of the pipe is too thin due to stretching. Sometimes the flare nut will not even go over the pipe. I have had some success, if they are not to badly stretched, with the gray fittings used with gray polly pipe which used to be used prior to PEX. Even there, the fitting put over the pipe will often not work. Sharkbite fittings will not work either.
If you unsolder the short stubs you show from the fitting, and solder a new stub made from new copper pipe in, it will work fine. The stretching does not generally affect the solder fittings, that is they do not expand.
Have fun!
Old 12-26-2012, 07:45 PM   #11
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Iíve run into this problem on all three Vintage Trailers Iíve owned.
OKÖ. I know this is probably stupid and over the top. But thatís never stopped me before.
Iíve got a small lathe and itís really easy to bore out the inside of a new compression fitting and silver solder it onto the expanded tubing. Now you've got a properly sized threaded end to attach the flexible supply lines to.
Yea. I know itís not practical for most but it beats anything else in the area of smug self satisfaction.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 12-26-2012, 08:12 PM   #12
1988 32' Excella
Robbinsville , New Jersey
If you go with the hose clamps and flexible tubing get good hose clamps (I have seen a package of 6 in a dollar store if you want to replace your floor, even with double clamps) and don't get the clear hose make sure it's reinforced for pressure and double clamps is a good idea.
Old 12-26-2012, 08:46 PM   #13
DryFly's Avatar
1972 Argosy 20
Well this all presents a conundrum.
I wonder if I'd be opening up a new can of worms by trying to unsolder the the short stubs. idroba, have you done this before? Any tips and do's and don'ts?
Several years ago I had a 1-1/2" water line that feeds a commercial building burst. The plumber and I dug it up and he installed a rubber sleeve that was held in place with two stainless hose clamps. It is still holding strong with no issues. I wonder however if the flex tube lacks the ability to be properly compressed? I would really prefer a sweat fitting if I thought I could get the old one off without creating more issues.
I hate plumbing.
Old 12-26-2012, 09:33 PM   #14
Protohyp's Avatar
take the proper threaded copper fitting that will connect to your braided line and sweat that to whatever diameter copper pipe you have that is close to the 3/8" it can be about a 2" length then connect that with the flex tube to your existing pipes.
