Old 12-26-2012, 09:41 PM   #15
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Braided hose and double clamps are holding after 5 years.....and I check them regularly. Like you I don't (can't) want to re plumb everything with pex.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 12-28-2012, 04:36 PM   #16
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
After trying everything else I could think of, including Shark Bites, I decided to use the same system FreshAir used. Here's a pic. I'll pressurize the system in a month or so (other projects are in the way - read honey do list). I'm pretty confident this will hold, but as with all my plumbing projects I'll keep a careful eye on it.
Thanks for all your help and input, as usual
Name:	Bath Plumbing 2.jpg
DryFly is offline   Reply With Quote
Old 12-28-2012, 05:06 PM   #17
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
NICE JOB. Looks good from NJ
But then again I'm 3000 mi. away when you pressurize.
Just kiddin
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-28-2012, 05:45 PM   #18
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have replace split copper with the same technique. Have not had any leaks.
Old 12-28-2012, 06:02 PM   #19
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I suggest you should cut a small piece of the original pile and take it with you to test fit new sweat fitting to use as adapters. You should find the fittings will have the same tolerances as the pipe. Some will be slightly larger/smaller than others.
If you do find you must use clamps and flexible pipe, slightly flair the end of the existing copper pipe to keep water pressure from pushing the flexible pipe off of the copper.
Alan
Old 12-28-2012, 08:44 PM   #20
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I can tell you that old copper tubing of the 1970's is not the same size as copper tubing of today. Just went through this on a re-plumb of an Argosy. I did not want to remove the existing drain valves and wanted to adapt them to Pex. No such animal available.
One word of caution in using the clear braided tubing. If you check the specs it is not suitable for hot water use. Yes, it will work for awhile, but every time it gets hot water through it, it wil swell until it eventually it will fail. Usually right under the clamp.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 12-28-2012, 09:09 PM   #21
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I remain convinced that with the dimensions you gave....375 and .3578 inches....the copper can easily, quickly and safely be emory papered down so as to use the standard compression bead and fitting.
Old 12-28-2012, 09:16 PM   #22
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by Melody Ranch View Post
I remain convinced that with the dimensions you gave....375 and .3758 inches....the copper can easily, quickly and safely be emory papered down so as to use the standard compression bead and fitting.
What just because the old copper is thicker?
Old 12-28-2012, 09:28 PM   #23
1979 30' Argosy
Jeddo , Michigan
flaring tool ?
You might try to compress the line a little using a 3/8 " flaring tool, just the line side and don't add the flare. Another option might be to slip a copper nut on the line and go ahead and flare it.
hardwoodjdc is offline   Reply With Quote
Old 12-28-2012, 09:36 PM   #24
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Try refrigeration tubing. 3/8 tubing is .375 o.d. and the sweat fittings are a loose fit and .3758 should be no problem. Also the clamps and hose will hold water but without barbs it can slip right off the tubing. Repairing an in-line split helps to capture the hose but unrestrained like your application is not as secure. And yes it will get soft and swell under pressure with hot water.
Cheers, Dan
~ Margaret Thatcher ~
