Join Airstream Forums Today
Old 01-12-2012, 05:43 PM   #1
1978 Argosy Minuet 6.0 Metre
Cottonwood , Utah
'78 Argosy 20 shower
As soon as the snow gets out of my yard I need to replace the shower in my Argosy. First. Does anyone stock replacement wall panels for the shower? The floor pan seems water tight however it's ugly with stains, but the wall panels have cracks in it and leaks. We used it a few times last summer and all worked except for the leaking in the walls. and then running out underneath. not a good situation. The cracks are large enough that I dont think epoxy or the like would work.
Want to do it right the first time. Thanks in advance for the help.
Argosyman
argosyman is offline   Reply With Quote
Old 02-03-2012, 09:48 AM   #2
1974 Argosy 22
Not sure on the replacement panels, however you may be able to use Fiberglass Reinforced Panels (FRP), probably availble at Home Depot, 4x8 sheets. For the pan in my 22' Argosy I used Rustoleum Plastic Paint. It is a fairly new formula from them. Works like a charm and looks great. I used it on the walls too. Give it plenty of dry time before touching it, the more the better. (4 days or so)
twilder is offline   Reply With Quote
Old 02-06-2012, 02:22 PM   #3
Cottonwood , Utah
thanks
Thanks for the info. I will look for the panels and rustolium paint.
Argosyman.
2011 International 25FB -- Freeze Damage to Shower Heads and Galley Faucets NJ2Cali Plumbing - Systems & Fixtures 10 02-01-2012 02:09 PM
Shower Door Replacement Kamiak General Interior Topics 1 12-05-2011 12:56 PM
Looking at 24 ft. Argosy crunch27 Member Introductions 5 11-04-2011 10:45 PM
Removing shower valve in 74 Argosy 24' twilder Sinks, Showers & Toilets 2 04-02-2011 08:28 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
