Found a leak in diaphragm and replaced it, put it back together, hooked wires back up and pump does not turn on.
1. checked all the fuses with multimeter. Good
2. pulled the pump back out and put it on the bench and hooked the motor wires directly to a battery, runs fine.
3. Pulled the pressure switch off and hooked up multimeter and pushing a small rod in pressure opening the switch moves and breaks contact fine.
The only thing I can think of that is left is the rocker switch in the overhead panel went bad. I read in the manual the switch comes out the front and looking down overhead cabinet it has a orange wire in and out and a blue wire.
I can't find anything in the shop manual that gives the color codes on control panel wiring. Been working on it five hours and thermometer is reading 100° in the shade and the
Sovereign is sitting in the sun, (are we having fun yet?)
Can anyone else think of anything left to check besides the switch? I am considering forcing it out of the panel from and replacing rocker switch with a toggle switch.
