Old 07-17-2015, 04:34 PM   #1
1973 31' Sovereign
osotoos , bc
'74 Sovereign black tank valve
I think I may have a valve problem. It only partially opens to drain, even with plain water. It no longer chugs, just trickles. Can anyone tell me how I go about fixing this issue?
torchflame is offline   Reply With Quote
Old 07-17-2015, 06:15 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Is it a center, or rear bath model? Rear bath models are easier to replace the valve.
Old 07-17-2015, 11:42 PM   #3
1973 31' Sovereign
osotoos , bc
It's a rear bath model. What can I do? is the part replaceable?
Old 07-18-2015, 06:02 AM   #4
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
I can only speak from center bath experience. I don't know if the handles work differently on a rear bath or not. Have never seen one... I replaced both of my valves on mine, because they both leaked. If the rear bath is like the center on valve operation, if the handle comes all the way out, the valve has to be all the way open. I would suspect something clogging up the drain pipe more than I would valve not opening, unless the handle doesn't come out all the way any more...
If you want to replace them, they are replaceable. I had the belly pan off of mine when I did it. Others on here will know more about rear bath...
-Red, not being much help...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 07-18-2015, 12:11 PM   #5
1977 31' Sovereign
Lynnwood , Washington
Believe it or not, I had a toilet paper clog. Grey water tank wouldn't drain.
FYI - I've got a center bath. Both grey and black tanks are connected to one outlet.
Here's what I did: Close the black water valve and back-flush the grey water line. It'll be messy. But that's what you'll hafta do.
Good luck.
Tom
TomKirk is offline   Reply With Quote
sovereign
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Black Tank valve redo GlenCoombe Waste Systems, Tanks & Totes 3 09-15-2006 07:05 PM
black tank leak above valve gary Waste Systems, Tanks & Totes 2 06-03-2004 08:42 AM
Black Tank Valve Repair 87MH Waste Systems, Tanks & Totes 4 01-27-2004 06:47 PM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 08:21 PM
