Old 01-14-2010, 08:03 PM   #1
2toomany's Avatar
1973 23' Safari
1963 19' Globetrotter
Forest , Mississippi
'73 Safari Galaxy 30
Hi Everyone,
I am in the process of replacing a galaxy 30 in my 73 Safari, I was wondering if anyone has gone though this. My main concern is that the Safari has limited space above the above floor black tank. I was thinking of a low profile bravura but some of the specs. list on there web do not add up (measurement from back to center hole is 11 on the bravura, its looks more like 10 is all i have). Any one else used this model? I have seen several suggestions for the sea/land lite but will have to compare more measurements tomorrow.
2toomany is offline   Reply With Quote
Old 01-14-2010, 08:06 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The secret compartment behind the toilet is going to be the limiting factor on your choice of toilet. If you don't mind losing the door to that compartment, you can probably use a Bravurra low-pro. Measure the thickness of the door to the compartment first, to make sure removing it will give you enough room.
Old 01-18-2010, 10:26 PM   #3
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
i sell a lot of valves for the new thetfords. i'd stick with the sealand if it will fit,should.
crestonrv is offline   Reply With Quote
Old 01-31-2010, 05:44 PM   #4
2toomany's Avatar
1973 23' Safari
Follow Up
Ok, I purchsed an Aqua Magic 5. After comparing measurements from different manfactures this was the only that would fit without removing the compartment behind the toilet. If I had to do over I may have taken a chance and purchased the sea land travel lite, but there site did not give a specfic length from back to center hole which was important to keep the rear compartment.
Pros
1 It fits!!
2 It works.
3 it's white, and not a sun bleached yellow.
Cons
1 Its cheap. I mean it is made of thin plastic very simple design and appears to not be made to last.
2 It has a narow seat, also made of thin plastic.
3 water saver option is useless, very low water pressure with foot padel depressed half way.
Don't get me wrong this is good economical solution, I was just hoping for a product similar to the old galaxy 30. The galaxy 30 IMHO was a sturdy/better design long term.
Maybe this will help others making this decision in the future.
Below is before and after.
Name:	73 safari bath 010.jpg
Old 01-31-2010, 05:54 PM   #5
2toomany's Avatar
1973 23' Safari
For some reason the before pix did not post, so lets try it again.
before
Name:	73 safari bath 007.jpg
ID:	95179   Click image for larger version
Safari :: 1996 Airstream Safari Land Yacht tlw12 Airstream Registry Discussions 0 12-18-2011 08:47 AM
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 0 08-19-2011 08:32 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
