Old 03-04-2014, 07:30 PM   #1
1972 25' Tradewind
Breaux Bridge , Louisiana
'72 Tradewinds Land Yacht--fresh water inlet?
Can anyone tell me what this part is called so that I can try to find another one. The first picture is taken from the outside of the trailer with the door pulled down to enable putting water into the fresh water tank. The second picture is taken from the inside looking out. This square part seems to be plastic and is obviously broken.
ID:	206815   Click image for larger version
nadiar79 is offline   Reply With Quote
Old 03-05-2014, 10:35 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
It is called a "fresh water fill port/door." I need to replace mine as well, but have found no drop in replacement.
Old 03-05-2014, 10:38 PM   #3
1972 25' Tradewind
Thanks for replying. We were also thinking that a replacement would be hard to find.
Old 03-05-2014, 10:51 PM   #4
1974 Argosy 20
Kooskia , Idaho
It was a Thetford part originally. I wonder if Andy at Inland RV has them or can tell us if they are available any longer.
Old 03-06-2014, 09:34 AM   #5
Belegedhel's Avatar
Houston , Texas
I'm not too jazzed about the design of the original. When it rains, an unexpectedly large amount of water gets collected by the fill port, which would contaminate my fresh water were I not currently collecting it in a bucket. I'm thinking of replacing it with a stainless steel fill port for a boat, but this option doesn't make any allowance for the breather lines.
Old 08-01-2016, 11:07 PM   #6
1972 25' Tradewind
Denver , Colorado
Agreed. My AS is currently just a shell with insulation, but when it rains water pours in the original city water inlet. No good. I actually have the inside of the inlet covered with tape right now to prevent this. I'm researching water inlet options, but can't figure out why the only recessed inlet offerings are plastic, and all the metal (brass, chromed brass, etc.) options stick out. I guess I will end up putting a metal inlet either on the bumper, or under the AS on the belly pan, as I don't want the water hook up sticking out the side of the AS.
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Old 08-01-2016, 11:50 PM   #7
1979 23' Safari
Wayland , New York
I replaced mine for the reasons mentioned above. They let in dirt when the rain runs down the trailer side, plastic was brittle and broken and there aren't direct fit replacements available. I followed another members path and used a marine fill and vent. Had to cut a "patch" to fit them over the hole that the removal of the old pos left, but it came out pretty nice. (I know there was a rivet missing below.)
Old 08-01-2016, 11:53 PM   #8
1979 23' Safari
Wayland , New York
I also added a New fresh water inlet, the one in the bumper frame less than 6" from the sewer connection just wasn't working for me.
Old 08-02-2016, 09:44 AM   #9
1972 25' Tradewind
Denver , Colorado
I haven't decided where to run my grey tank outlet yet, so I should be able to avoid the "both holes in the same place" syndrome.
I like the look of the inlet you used, but I wish it were actually metal instead of chromed plastic, especially with how much it will get banged with the hose nozzle. I may have to end up fabricating the recessed part and using the protruding metal marine inlet.
Old 08-02-2016, 09:51 AM   #10
1972 25' Tradewind
Denver , Colorado
I do like the look of that flush mount inlet. How much of a pain is removing the cap for filling? The location of the original inlet also seems odd (going through the outside, into the sink area, through the floor, and finally to the tank --not to mention being pretty conspicuous right in the middle of the side of the AS). I will likely relocate to a position that makes a little more sense.
Old 08-03-2016, 09:23 PM   #11
1979 23' Safari
Wayland , New York
"How much of a pain is removing the cap for filling?"
Not very, they have a 'key' that goes into the face to remove and replace and there are 'keys' that have a little bit of a handle for leverage if needed. It's not something you're opening and closing too often.
"I wish it were actually metal instead of chromed plastic"
Me too, but the rv industry demands cheap. A 90degree elbow between the hose and inlet can help cut down wear.
Old 08-03-2016, 10:36 PM   #12
1972 25' Tradewind
Calgary , Alberta
Kinda confused? Did you mount two fresh water inlets beside each other?
Monza is offline   Reply With Quote
Old 08-04-2016, 12:00 AM   #13
1979 23' Safari
Wayland , New York
Farthest left one is for fresh water from a pressurized source(hose).
The two on the right are for filling the fresh water tank for use when boondocking. Of those two the round one is a marine fill for Gravity filling tank, the small thing next to it is a vent for the tank. The original crappy flip out door incorporated both fill and vent, which was possible since it didn't seal tightly.
Old 08-04-2016, 09:08 AM   #14
1972 25' Tradewind
Calgary , Alberta
Thanks for the reply. I think I'll do my '73 like your set up.
1976 Sovereign fresh water tank drain drbseeker Fresh Water Systems 5 12-23-2011 10:38 PM
Outside fresh water door lock won't open willbrackman Exterior Storage Compartments & Access Doors 12 11-02-2011 01:27 AM
Removal of 1973 fresh water tank Belegedhel Fresh Water Systems 6 08-05-2011 08:32 AM
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 11:46 PM
Placement of new water inlet??? robwok Plumbing - Systems & Fixtures 14 03-02-2011 10:01 PM
