Old 08-04-2016, 10:10 AM   #15
1979 23' Safari
Wayland , New York
The hardest part for me was getting the fill hose between the marine fill and tank connected. My replacement tank came with 1-1/4" inlet vs the original 1-1/2" so I had to get some different size hose and an adapter(not easy to find) to join the 1-1/2 to 1-1/4 hose. Getting the new hose on the adapter barbs was a PITA.
Otherwise making sure the spot for the new pressurized fresh water inlet had clearance behind it and nothing in the wall to hit. Then drilling a big hole in the side was a little nerve wracking, you only get 1 chance and don't want to f it up. If you go that route hit me up on suggestions for drilling the holes.
Old 08-06-2016, 08:27 PM   #16
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Highjoesilver where did you get the vent cover? That's looks great! I've already placed the same marine fill.
Matt
rugjenkins is offline   Reply With Quote
Old 08-07-2016, 01:13 AM   #17
1979 23' Safari
Wayland , New York
Got it on amazon. It says 5/8" but it fit the 1/2" black poly tubing that I used for the vent. Depending on what you've got on your tank vent you may need ya adapt from 1/2" to 5/8". They have some different looking ones on Amazon.
https://www.amazon.com/Perko-0506DP4.../dp/B0009TNKCM
1976 Sovereign fresh water tank drain drbseeker Fresh Water Systems 5 12-23-2011 09:38 PM
Outside fresh water door lock won't open willbrackman Exterior Storage Compartments & Access Doors 12 11-02-2011 12:27 AM
Removal of 1973 fresh water tank Belegedhel Fresh Water Systems 6 08-05-2011 07:32 AM
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 10:46 PM
Placement of new water inlet??? robwok Plumbing - Systems & Fixtures 14 03-02-2011 09:01 PM
