Old 06-09-2006, 09:43 PM   #1
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
'71 safari-Question
I have not been able to open the water fill latch on my 71 safari-does it just twist open?-Im dying to see if this baby holds its water! how do I open it?-looks as if it is broke-thanx for your advice--jim
jamesardis is offline   Reply With Quote
Old 06-09-2006, 11:37 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
It is like a drawer - it pulls straight out. Looks like yours has the tabs to pull it out and lock broken off. You might want to start shopping for a new water fill thingie. Chances are this one is sort of busted.
If you can grab onto anything that sticks out from the center round part and yank straight out, it might open, revealing it's intricate insides....
Uwe
www.area63productions.com
Old 06-10-2006, 12:37 AM   #3
1992 34' Limited
Falls Church , Virginia
Cool!!! Something 'new' for me!
Hey, really neat!
I haven't yet seen one of those before. I wouldn't have known how to open it either! Now I do! Kudos Uwe.
Good luck on the 'holding water' situation. Replacement too!
Axel
SilverToy is offline   Reply With Quote
Old 06-10-2006, 09:33 AM   #4
Darol Ingalls's Avatar
Since the tabs are already broken off, drill a pilot hole in the center, screw in a large headed sheet metal screw part way, grab the head of the screw with a vice grips, pull and wiggle until the round center portion slides out. Sand and dirt has most likely gotten between the sliding parts. 35-year old ABS plastic will probably break, so plan on replacing with a new part. Look for a better designed one at a good RV parts store. You may have to cut a little larger hole in the side of the trailer (AFTER you find a new one!), but there are styles that fill much easier than the original one. Check that the hose from the fill to the tank will fit on the new part before installation - there have been some size changes over the years. Darol
Darol Ingalls is offline   Reply With Quote
Old 06-10-2006, 02:09 PM   #5
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
Thank you Uwe and Darol--yup I used pliers and it pulled out easily-I guess I thought that it had to twist not pull--looked pretty dirty-cleaned it out and am finally going to see if this safari will hold water-Im nervous!-thanx again guys--jim
Old 06-10-2006, 02:17 PM   #6
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Neat little drawer, ain't it?
The water fill is available from standard RV supply shelves - replace it so you have a clean water supply. Plus, the new ones you can lock for security.
Uwe
New to Us - 1966 Safari - Overseas Caravan O-4 & WBCC Number Question corinnedavid Airstream History 2 01-03-2012 11:31 PM
Safari :: 1996 Airstream Safari Land Yacht tlw12 Airstream Registry Discussions 0 12-18-2011 08:47 AM
'64 Safari Converter Question Fan/Pump Switch Castiniron Batteries, Univolts, Converters & Inverters 6 09-15-2011 07:24 AM
'64 safari steps repair question Homewrecker Steps 4 03-14-2011 03:01 AM
