Have 71 overlander. Water pressure off the city is fine. When using the pump all i get is a trickle. Wondering if this is related to the water pump or possibly the the EVERPURE EN-1 water purifer under the galley sink. My manual says over time as the filter fill with impurities the rate of flow will gradually decrease.
Does this filter work for both city water and fresh tank water???
Same happened to me.I checked the strainer on the pump. it was clogged with caulking from trailer.how it got in there who knows 19 years .
Thanks i take it, the strainer for the water purifier is different than the strainer on the pump? the strainer on the purifier i checked the pump i did not. thanks for the clue.
