Join Airstream Forums Today
Old 09-08-2011, 05:16 PM   #1
1964 24' Tradewind
Howell , Michigan
'64 Land Yacht
I orderd the adapter for my waste tank. I got it but it don't fit. The older models are a pintch larger. I am trying to conect to my dump valve. It is made of metal and has 4 slip hooks. can anyone tell me were I can get parts to fit a 64. Please help tommyt.
tommyt is offline   Reply With Quote
Old 09-08-2011, 06:00 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 170
64 land yachy
Greetings tommyt!
Your coach evidently has the original metal dump valve. Those valves have been obsolete for many years and the necessary adapters are virtually unavailable. The only source will be on the used market. The adapters are aluminum or pot metal and I am not aware of any modern plastic parts that will work with the metal valve. Most of us with coaches that came from the factory with the metal valves have replaced them with modern Thetford hardwared. My Airstream dealer handled the process for me as it required cutting the original metal valve out and fiberglassing a new Thetford valve into the tank. Members on the list who have rebuilt their metal valves have either had the adapter parts that were included with the coach or they located original parts via web-based classifieds.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 09-08-2011, 06:00 PM   #3
1960 24' Tradewind
Riverside , California
The bronze dump valves and aluminum drain fittings haven't been available for many years, may find someone who has some old ones, otherwise it's a conversion to the newer style Thetford fittings.
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
ZoomZoom is offline   Reply With Quote
Old 09-09-2011, 06:18 PM   #4
1964 24' Tradewind
Howell , Michigan
Smile Another Thank You
I took the fittings I orderd, bought some good glue,glued it and put it in backword. I think it will hold tell I can take it all out and replace the old valve with the newer type. Thanks again for all the info.
Two weeks tell the Tin Can rally at camp dearborn Michigan. It's our first AS and first rally.
