Old 09-25-2016, 08:05 PM   #1
1971 21' Globetrotter
1965 17' Caravel
1951 15' Cruisette
45 Gallon Freshwater tank
My 71 Globetrotter has a flat freshwater tank. I have three connections (actually the 4th one is the fill connection. 1 on the top left, 1 on the top right and one on the bottom. I assume the bottom one is for the drain and the two top connections are vents. My question is where do I hook the water pump to? Thanks to all!
Katybelle
KATYBELLE is offline   Reply With Quote
Old 09-25-2016, 08:09 PM   #2
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
The bottom one. There should be a drain in between tank and pump to allow you to empty the tank without having to use pump.
Al Boondy is offline   Reply With Quote
Old 09-25-2016, 08:12 PM   #3
1965 17' Caravel
1951 15' Cruisette
So the pump should connected to the line leading to the drain? thanks
Old 09-25-2016, 08:17 PM   #4
1965 17' Caravel
1951 15' Cruisette
Also, where does the other vent connection go? I know now goes to the fill up connection. Thanks.
Old 09-26-2016, 01:42 PM   #5
Al Boondy's Avatar
Leading FROM the drain. From tank to a tee for drain then to pump.
You can plug one vent or put a tee so both vents enter tee then have one line to filler connection.
Old 09-26-2016, 01:50 PM   #6
1979 23' Safari
Wayland , New York
I would plug one of the vents, use the one that's most convenient.. Tie the pump suction into the bottom drain connection. Depending on where the bottom connection is you can use a T fitting to feed drain and suction or put suction in drain line. Just be sure drain slopes level or down.
Vintage Trailer Supply 20 gallon fresh water tank mello mike Fresh Water Systems 5 08-01-2010 04:37 PM
04 28 safari 70 gallon combined black and gray tank safari 28 Waste Systems, Tanks & Totes 6 11-07-2007 09:53 PM
6 gallon?....10 gallon?.... FreshAir Water Heaters, Filters & Pumps 16 06-15-2007 04:57 PM
Safari 30' Bunk: why 18 gallon black tank? LittleRadio 2006 Safari 28 05-24-2007 07:38 AM
What size is it 54 or 60 gallon (FW tank) M&M CAPECOD Waste Systems, Tanks & Totes 2 09-24-2004 11:32 AM
