Old 03-23-2011, 08:22 PM   #1
jsapp's Avatar
1987 34' Excella
Bonifay , Florida
34' Excella toilet spray?
I have taken my AS out once since I purchased it and noticed the toilet would spray a little fresh water from the rear base when flushing. I didn't use an external pressure reg in hopes that the internal one was functional. Is my problem a failed reg or do I need to pull the toilet up?
jsapp is offline   Reply With Quote
Old 03-23-2011, 08:34 PM   #2
Pull the toilet.
You should find that the "water flush valve" s leaking.
Old 03-24-2011, 04:00 AM   #3
jsapp's Avatar
1987 34' Excella
Bonifay , Florida
Thx, looks like I have a weekend project!
Old 03-24-2011, 05:59 AM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
You can purchase replacement flush valves. The seal is most likely dried out.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 03-24-2011, 07:10 AM   #5
1986 25' Sovereign
Plant City , Florida
Don't Purchase a new valve
The problem is your flush valve. If you remove the part you will see that this shaft is turned when you step on the pedal. You can remove the flush shaft and replace the O-ring with one from lowes. I did this 2-3weeks ago with no issue. I think a pack of 20 rings cost me .89, so this is much cheaper. If you have any questions feel free to pm me.
ck21084 is offline   Reply With Quote
Old 04-25-2011, 05:12 AM   #6
jsapp's Avatar
1987 34' Excella
Bonifay , Florida
I have replaced the flush valve and found that the spray is coming from the valve near the top of the toilet. The PO had used an excess of grey silicone around the piping. I see a new aquamagic in my future...
Old 06-09-2011, 10:37 AM   #7
jsapp's Avatar
1987 34' Excella
Bonifay , Florida
The best fix was a new unit. $169 fixed all the leaks!
Liquid Wrench Silicon Spray? Janie Q Windows & Screens 3 03-22-2011 02:09 PM
Toilet mounting flange Green68 Sinks, Showers & Toilets 7 03-21-2011 08:21 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
mounting toilet flange on black tank 386kustoms Sinks, Showers & Toilets 3 03-04-2011 07:52 AM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
