Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 06-14-2005, 01:53 PM   #1
Scott_F's Avatar
1970 31' Sovereign
Eugene , Oregon
31' 1970 Sovereign water leak
Hello,
I have a 31' 1970 Sovreign that is dripping water out of a (drain) tube next to the waste dump fitting when the water tank is pressurized by the water pump. There are two such drain pipes (they look like 3/8 " sugical tubing), one on each side of the dump fitting. As you look at it, facing forward, it's the one on the left. The right side tube drains when either of the rear pressure relief valves are opened. Is there maybe a drip pan under the hot water tank that is collecting a leak? My original owners manual does not mention this drain.
Scott Fischer
Scott_F is offline   Reply With Quote
Old 06-14-2005, 05:27 PM   #2
Scott.
At the rear of your Airstream, there are two drain valves that are used when winterizing. Clear colored hoses are attached to them and go through the underbelly.
Those valves, as with any valve can leak in time.
There is another drain hose connected to the "111" valve. That valve will blow off any excess water pressure from a city water supply. In time, they can start seeping as well.
Airstream did not install any pan under the water heater.
Andy Rogozinski
Inland RV Center
Corona, CA
Grey water in a '71 Sovereign? CeloNC Waste Systems, Tanks & Totes 30 08-29-2018 10:50 PM
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Toilet Fresh Water Valve Leak perryg114 Sinks, Showers & Toilets 7 10-11-2011 06:41 AM
Frustration !!Water leak at front of trailer!! william Haym Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-06-2011 11:41 AM
Water Leak bumper Airstream danyfr67 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 06-07-2011 07:43 PM
