Old 09-21-2011, 09:36 AM   #1
stream lady's Avatar
2005 19' Safari
2005 19' Safari
new iberia , Louisiana
1977 overlander water leak
Our first trip out in the overlander since purchase and seems all was going good when a water leak has been found in the rear,seems like the pbc piping is leaking on the bath room sink or tub drain ,OK now how do you get up in their to fix whatever is leaking ? Its hard to get both hands up in their? I'm sure someone has had this happen. thanks for any help.
Sarah & Howard
stream lady is offline   Reply With Quote
Old 09-21-2011, 10:28 AM   #2
Sarah & Howard
Sarah.
More than likely the trailer sewer vent pipe cover gaskets are leaking. They only last 2 to 3 years.
They can easily be reached from a step ladder.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-21-2011, 03:21 PM   #3
2005 19' Safari
2005 19' Safari
Leak
Thanks Andy,now would that be leaking even if we had no rain ?
Old 09-21-2011, 03:47 PM   #4
No.
Only rain or a wash job would cause water to bypass that gasket.
Water can only then come from within.
Possible the AC drain water, or a leaking water fitting.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-22-2011, 11:44 AM   #5
2005 19' Safari
2005 19' Safari
leak
We have checked out the leak the best we can see its a fitting around the shower area, drain or pipe.now how do you get to all of this?
Sarah
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Water Heater on 1977 overlander stream lady Water Heaters, Filters & Pumps 11 07-24-2011 09:51 PM
Water Leak bumper Airstream danyfr67 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 06-07-2011 07:43 PM
Water Leak in Plumbing eldin Fresh Water Systems 8 03-17-2011 07:43 AM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
