Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 07-25-2004, 09:00 PM   #1
RamblinRose
Profile:  Vancouver
Post 1977 23' Safari Plumbing System
Hi all,
Any chance someone out there has the service manual pages showing the Land Yacht drainage system schematic? Would appreciate a scanned or digital image if possible. We've got some BAD smells coming from under the bathroom sink area and the bathroom closet area (see my thread under General Repairs). So far we have filled and drained all tanks, hosed water through the roof vent into black and grey holding tanks to check for clogged pipes, drained again, and can't find anything wrong...but it still stinks! The problem just started today at the end of our 3rd weekend trip. Our trailer didn't come with a service manual--I'm going to order a photocopy, but we leave for a 10-day trip next Sunday. Any help would be much appreciated.
Kate
RamblinRose is offline   Reply With Quote
Old 07-25-2004, 10:58 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Kate,
I am afraid that you might have trouble with your toilet or black tank.
There might be a leak at the toilet flange, or a problem with the dump valve, perhaps even a defective holding tank.
A close inspection of the toilet system with a bright flashlight might reveal the cause of your unpleasant odors.
Take a close look, and post your findings. Someone will surely chime in and help you solve the problem.
Uwe
Old 07-25-2004, 11:43 PM   #3
JohnG
JohnG's Avatar
Profile:
From a 1974 Service manual
Originally Posted by RamblinRose
Hi all,
Kate
This is from a 74 service manual hope it helps. If you need me to send them to you via email shoot me a PM with your address.
ID:	8024  Click image for larger version
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-25-2004, 11:45 PM   #4
JohnG
JohnG's Avatar
Profile:
Try For a bigger image
Hope this image is a bit better
John G
Old 07-26-2004, 07:28 AM   #5
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
If your plumbing matches that on the posted schematic, I'd check the vent pipe's connection to the black tank...you can see it in the closet way back there in the corner. make sure that is securely attached. another thought is the toilet itself: is the bowl holding water? if that seal is not closing up properly, and water leaks into the black tank, that means air can (and will) escape up into the bathroom. The groove that the "blade" slides into can get clogged w/ tp or other gunk, preventing it from closing all the way. it can be cleaned out w/ a bent coat hanger.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-26-2004, 12:32 PM   #6
RamblinRose
Profile:  Vancouver
Smile Thanks Guys!
John G - thanks a million for the schematic--I'm sure it's the one we need and it printed quite clearly. Chuck & Uwe - thanks for the suggestions--I'll pass the info on to my husband....I do the research and he does the work (but I'm learning). I'll post when we find the source of the smell (or if we need more help!).
Thanks again,
Kate
Bringing a Plumbing System out of Long Term Storage 66Overlander Plumbing - Systems & Fixtures 5 05-18-2004 07:47 AM
1977 Safari Manual RamblinRose General Interior Topics 2 04-17-2004 04:51 PM
new plumbing system Lexxy Fresh Water Systems 4 08-04-2003 10:38 AM
How to check charging system (69 Safari) Bob Boucneau Electrical - Systems, Generators, Batteries & Solar 2 07-14-2003 10:48 PM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 05:49 PM
