Old 03-16-2019, 09:29 AM   #1
On an Aluminum Diet
ZeeroG's Avatar
1968 20' Globetrotter
Houston , Texas
Wheel stuck to axle.
Twice now in one month, my wheel has stuck to my axle. Had to beat it off with a sledge hammer. New tire, then had to fix new tire and both times a nightmare to remove tire from trailer. Itís a newer 2012 axle. Afraid to put fixed tire back on should it stick to axle again next time I have a flat. Any thoughts?
ZeeroG is offline   Reply With Quote
Old 03-16-2019, 09:42 AM   #2
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Is there any rust on the hub?
I see you are in Texas so rust issues should be minimal but, that could be the problem. Check the out side of your hub where it goes in the wheel and inside of the center hole in your wheel. If there is any rust, clean it up with some sandpaper. Maybe put a little axle grease where they mate. That may help as well.
Gregsch is offline   Reply With Quote
« What is this part? | Top | - »
Zip Dee Wheel Lock Stuck Kevio Awnings 27 09-06-2018 09:56 AM
Belly Pan Stuck Near Axle Greg1410 Belly Pans & Banana Wraps 15 10-15-2015 11:56 AM
Stuck steering wheel abridges01 Airstream Motorhome Forums 32 08-11-2013 12:16 PM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
Four Wheel Drive or Two Wheel Tow Vehicle? 1cericks1 Tow Vehicles 24 02-01-2009 02:22 PM
