Old 04-20-2013, 12:48 PM   #1
1966 20' Globetrotter
Globe , Arizona
Wheel! bearing seals - 1966
I have a 1966 Globetroter that has been sitting for 20+ years that I am starting to rebuild. I have gotten the breaks and bearings apart and managed to find all of the parts I need except for new bearing seals. The seals that were installed were National 292100. All of the parts houses I have talked to so far have been un able to cross them to something that they could get. Does some one have a suggestion of who to contact?
Mike_cfi is offline   Reply With Quote
Old 04-20-2013, 01:13 PM   #2
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
My seals were national also (442109) on my 68 tw and I was able to get new seals from NAPA Autoparts. My rear timken bearing # 25580. Hope that helps.
Kevin
kevinb is offline   Reply With Quote
Old 04-20-2013, 01:14 PM   #3
"Cloudsplitter"
Question
Try cross referencing this, TCM 223263TB, at a local Auto store.
Do you have an old seal to compare?
"You don't know where you've been until you leave, enjoy life" RLC
Old 04-20-2013, 01:19 PM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
this from Vintage Airstream:Wheels & Axles - Vintage Airstream
Another area that you need to be aware of are the different grease seals available. Many RV outlets have a simple single lip seal that will fit in Airstream axles. Airstream does not use nor do they recommend the use of single lip seals. Their recommendation is to use double lip seals only. They may be a little harder to find is a small price to pay for the added security.
The original P/N was a National 291148 felt seal and 292100 in the ‘60s Henschen axle. The 292100’s are available from OasisRV. The TCM 21325TB
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 04-20-2013, 01:20 PM   #5
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Take the old seal to an auto store to make sure they match. Make sure you get all the old grease cleaned out of the hub. Don't mix greases. Get a good bearing grease with a high drip point. I got marine and bearing grease with a 500˚ drip point at Ace Hardware.
Read up on the threads about wheel bearings for advice on how to tighten the castellated nut—too tight and the bearings will burn out.
Good advice from Excella above about getting good quality seals.
Gene
Gene
Old 07-07-2013, 07:11 PM   #6
Globe , Arizona
Smile Success
Thanks for all of the help. Bearings are repacked and trailer successfully towed home.
1966, 1966 globetrotter
Bearing grease seals Sailor-d Wheels, Hubs & Bearings 7 08-16-2012 12:43 PM
1968 Caravel bearing seals coopermr Wheels, Hubs & Bearings 10 08-22-2011 11:14 AM
wheel bearing lube 1989 excella murphy Wheels, Hubs & Bearings 1 06-21-2011 07:25 AM
Wheel Bearing Help Needed mile2885 Wheels, Hubs & Bearings 31 06-16-2011 10:22 AM
Seals For Wheel Bearings ~ 1958 Pacer Ariz-Pacer Wheels, Hubs & Bearings 9 03-22-2011 10:50 PM
