Old 06-17-2015, 10:19 AM   #1
london , Ohio
water leak
Have a leaking gasket on what I think is the water pressure regulator on a 1969 Globetrotter. There seems to be a cap on the bottom but it is rather hard to get at and even a 10" adjustable wrench seems too small. Any suggestions for repairs in central Ohio?
ID:	240941   Click image for larger version
Name:	Pressure Regulator or Relief Valve.jpg
old hen is offline   Reply With Quote
Old 06-17-2015, 10:40 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Suggest you remove it entirely and replace with a modern one.
BambiTex is offline   Reply With Quote
Old 06-17-2015, 12:48 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Hello old hen
If you're hiring the work out, then the Airstream service center in Jackson Center would be able to help you with that. It is adjacent to but mostly separate from the Airstream factory, from what I understand. By all reports, their capabilities are considerable and their rates no higher than all the other places (I've never been myself, it's too far).
The "leak" arrow in your photo points to the check valve portion of a combined check valve and pressure regulator. There is an access plug there for cleaning and service of the check valve swing assembly. There are three approaches to the repair:
1) Remove the check valve and regulator assembly from the trailer so that a bench repair may be made. This would allow wrenches of any size, impact tools, and torches to be brought to bear, as necessary.
2) Repair the check valve plug gasket in-place as you are attempting to do. If I were doing this, I'd try to get a 6-point socket wrench in there on the end of a long breaker bar. If there isn't room for that I'd try the box end of a combination wrench.
3) Remove and discard the assembly and replace it with a modern equivalent.
The check valve is necessary but the regulator less so. It's rare to run into campgrounds that have a problem with high water pressure -- I've done so once in all my travels. Easiest thing to do when encountering that, except for a long-term stay, is just fill the freshwater tank from campground water supply and run the pump.
Old 06-18-2015, 07:26 AM   #4
london , Ohio
Thank you for the tips. That helps with the decision making. Looks like replacing the whole unit is the way to go.
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
