Old 11-08-2017, 08:05 AM   #15
Originally Posted by Didgiman View Post
I have purchased the mailbox locks to replace the existing locks for my access door. Here is the catch: I can't get the old locks out of the door. The tumblers slipped right out and the paddle that actually holds the door in unscrewed, but the outer housing will not slide out of the door. It seems that I am on the brink of seriously destroying the door by beating and prying the lock out. What is the secret here.
Sincerely,
Didgiman
I just experienced this problem. Thought I would share my experience. Once you remove the lock cylinder, you should be able to remove the entire door. You will need to remove two of the screws that hold the door frame together, then slide the door facing out. There is a metal clip inside the door that holds the lock in place. You will never get the lock bezel out without dismantling the door panel. Good luck.
ID:	298636   Click image for larger version
ID:	298638   Click image for larger version
mikejbuckley is offline   Reply With Quote
1968 Airstream Tradewind 24 - Oregon devbec1968 Airstream Classifieds 0 02-08-2014 02:32 PM
Curious about storage compartment AirHome Exterior Storage Compartments & Access Doors 7 07-27-2011 10:51 PM
Basement storage compartment hinge lubrication. BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 05-03-2011 04:35 PM
