Old 01-05-2009, 07:14 AM   #1
cooksey69's Avatar
1969 21' Globetrotter
apache junction , Arizona
Rear bath remodel help on '69 GT
I just acquired a 21' 69 GlobeTrotter over Christmas break. I have completely stripped the interior and am in the process of sealing exterior and replacing entire floor. The original bath had no holding tanks and I would like to make it larger. Any suggestions on remodeling bath and how to add grey and black holding tanks to this trailer? I am thinking of putting bath area completely across back with seperate shower.
cooksey69 is offline   Reply With Quote
Old 01-05-2009, 08:15 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Welcome to the Forums. I am currently in a long term restoration / remodel of a 71 GT, but am moving the bath to a side wet bath. Finding a gray water tank that will fit between the frame rails without hanging below the belly pans has been a challenge. I found a tank that will fit but it only holds 11.6 gallons so it will require at least 2 tanks that will mount one under the axle, and another, one bay aft of the axle, and then plumbed together. I would be very cautious about mounting a gray tank all the way aft as it would cause a loss of tongue weight as it fills up and the freshwater tank empties, as it is in front of the axle, causing serious towing issues. You should already have a black tack under the toilet. Do not be afraid to ask lots of questions.
http://www.airforums.com/forums/f381...nte-26902.html
Old 01-05-2009, 08:17 AM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Thats what I have in my 69'. When adding tanks you need to be carful. If you put your black tank in the back you may need to strengthen the frame so it doesn't sag. 10-15 gal max should be fine for a black tank. Your grey tank try to fit in between the axels (if you have 2) 20-40 gal for this. I am adding a grey tank this spring (30 gal) I am going to re plumb the black tank to come out the side with the grey so i only have one hose to hook up. Each tank will have a valve that can be opened and closed into the one outlet valve. put the toilet directly on top of the black tank. and the shower on the interior wall closest to the front. That way you don't have to run you plumbing as far.
Good luck.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 01-05-2009, 08:22 AM   #4
purman's Avatar
1968 28' Ambassador
Aerowoood brings up a good point about the size of the tank. My grey tank is going to be my old water tank. It is only 6" tall so it will hang down from the frame, but as it is going between the axels it will not hang below them.
you can get them custom made, little more money but worth it for the black tank, as you don't want the outlet to have seams that can catch on stuff (if you know what i mean)
Talk to your local RV dealer about tanks and tank sizes. Talk to more than one because they carry different lines of tanks.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 03-28-2010, 06:14 AM   #5
JFerguson's Avatar
1964 26' Overlander
Gloucester , Virginia
I don't want to hijack this thread but I was wondering how feasible it would be to fabricate your own tank. I have some fiberglass layup experience from a sailboat I built years ago. I was thinking of shaping a chunk of styrofoam to shape of the tank coating it in several layers of fiberglass and then pouring a cup or two of gas in there and disolving the styrofoam.
JFerguson is offline   Reply With Quote
Need help with Rear Bath falling out. Slowride66 Repairing/Replacing Floor &/or Frame 32 06-17-2012 05:10 PM
1979 Rear Bath Complete Remodel Advice suzie Sinks, Showers & Toilets 0 06-10-2011 03:33 PM
Painting Rear bath options SilverHoot General Interior Topics 11 04-07-2011 08:31 AM
Replacing the floor in a rear bath elkie2331 Repairing/Replacing Floor &/or Frame 4 04-04-2011 07:35 PM
