Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Globetrotter > 1965 - 1969 Globetrotter
Old 03-05-2011, 04:49 PM   #1
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
Propane Gas lines exposed - 1968?
Hi,
I am undertaking the restoration of the frame and changing out all the water and propane lines. My 1968 Globetrotter has the propane lines exposed to the elements and on hangers outside the bottom wrapping. This can't be correct. Can anyone give me their opinion? I intend to hang them inside through the crossmember frames. If I am right, are there rubber grommets available for hanging these 5/8" pipes? Also, the entire area under the floor was spray foamed. Thought they did not do that at the factory. Seems solid though. Thanks again.
Randy
Randy Gates is offline   Reply With Quote
Old 03-05-2011, 04:54 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The propane lines do run on the outside of the belly pan supported by a few clamps just as you described. This is to allow any leaks at the shutoff valves to fall to the ground. If you place the lines inside the trailer or even inside the belly pan you could create a pocket of explosive gas if you had a leak.
Richard
Old 03-05-2011, 04:55 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Randy. That is absolutely correct. Except for termination at a consuming appliance, there can be no joints or valves inside the shell of the trailer. Thus everything is suspended below. On new units, Canada code dictates that a rubber shielding be installed over the copper tubing. Wish they'd build all units that way.
5 meter Langford Nahanni
Old 03-05-2011, 04:55 PM   #4
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Hey Randy, I think it is normal for the propane lines to be outside the belly pan. My 65 Safari is like that.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 03-06-2011, 11:18 AM   #5
RGates
Major Thanks Guys!
We were at that point where the pipes were going to be measured out and cut. That simplifies things. Outside, but foam encased they will be.
Randy
Old 03-06-2011, 11:25 AM   #6
Randy
Spiral cut water hose, is much easier, and no "mess".
Andy Rogozinski
Inland RV Center
Corona, CA
Help! Heater and Propane issues AustinAir LP Gas, Piping, Tanks & Regulators 19 12-24-2011 05:02 PM
No Gas to range cuyd Stoves, Ovens & Microwaves 22 06-27-2011 07:09 PM
LP Gas lines 59as LP Gas, Piping, Tanks & Regulators 6 05-01-2011 05:46 PM
Propane phobia. ROBERTSUNRUS LP Gas, Piping, Tanks & Regulators 18 04-27-2011 11:37 AM
