Old 03-18-2015, 05:23 PM   #15
flygrrl
flygrrl's Avatar
1962 19' Globetrotter
Winchester , Ontario
A little hit
Check this out, page 6 right column. He talks about Murphy Co.
ISSUU - Airstream Life Fall 2010 by Church Street Publishing, Inc.
TV: 2007 Jeep GC Laredo diesel
Toy: 1995 Jeep YJ
Experience is what you get from not having it when you needed it.
flygrrl is offline   Reply With Quote
Old 03-18-2015, 05:28 PM   #16
flygrrl
flygrrl's Avatar
Have you actually taken a tape measure and confirmed the length? On looking at the sideways pic in the dark, she looks quite long, longer than my globie.
Toy: 1995 Jeep YJ
Old 03-21-2015, 08:24 AM   #17
M.C
1967 20' Globetrotter
MIAMI , Florida
Finally got the time to measure it, from ball to end bumper is 21'
M.C is offline   Reply With Quote
Old 03-22-2015, 06:26 AM   #18
M.C
MIAMI , Florida
More pics; check the hose conection on rear bumper street side( maybe indicate toilet side?), window to the left of entrance door ( probably they change it with plexiglass and add frame to it to shape it).
ID:	234726   Click image for larger version
ID:	234728   Click image for larger version
ID:	234730   Click image for larger version
ID:	234732   Click image for larger version
ID:	234734   Click image for larger version
Old 03-22-2015, 07:58 AM   #19
flygrrl
flygrrl's Avatar
Yeah, she is longer than my Globie. Nice. Looks like you have the Corning curved windows, be very, very careful with those, I hear they are made of unobtanium.
Toy: 1995 Jeep YJ
Old 03-22-2015, 01:47 PM   #20
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Model of trailer
M.C., From what I see in your pictures Your trailer would appear to be a 1967 22 foot Safari rather than a 20 foot Globetrotter! The way to know for sure would be to measure from the outside of the back bumper to the front edge of the hitch ball. The body/overall length will be shorter than 22 feet but that's how Airstream factory (measured) them. The picture with the louvered vents is for the water heater not for a refer. The windows do not have the edged stainless steel trim that would be factory for a '68 model, w/o trim is factory for a '66 or '67 model. I will keep looking at the rest of your photos but this is most likely a '67 model. I'll post back here if I see anything else that help to identify your trailer. The photo that shows the missing plate beneath the window where the faded glue remains of the dealer sticker is located is where your model serial/VIN plate should be. See if you can obtain any info from the seller you got the trailer from as to paperwork or registration that would show how the trailer was last licensed and the state that would allow you to search for more info. If you cannot get anything that way PM me and I may be able to share some other ways in which to might be able to Identify the trailer so you can get a title in your name. Hope this helps, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 03-24-2015, 08:04 AM   #21
M.C
MIAMI , Florida
Unfortunately I found nothing so far on previous owners; I don't know much about Airstream but for what I see on pictures, window on the street side looks like a bit different, also the refrigerator vent is on street side too, Thanks again for all the help BIGED52 !!!
Old 03-24-2015, 03:02 PM   #22
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Hints from pictures
M.C , You can get new glass for your windows from Airstream dealers or from VintageTrailerSupply.com. My refrigerator is on the street side so if your vent is on the same side as the two large windows that would make sense. The round vent stack at the street side rear is the vent for the bathroom as a plumbing vent. The small window to the left of the entry door is normally located above the galley sink. I don't believe the window to the right of the door is found on the Globetrotter. However this trailer could have been a custom order. Check to see if that window opening is 17.5" X 20.5", if so it is likely a Safari 22 foot model. Ed
Old 03-25-2015, 07:39 AM   #23
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
The globe trotter
Some fun facts about GTs... Generally speaking, and with Airstream's caveat “Specifications subject to change”.
The name Globe Trotter may have first appeared as a sub-model of the 22ft liner in 1948.
The name disappeared until around 1954, reappearing as18ft, then vanished again until perhaps 1958 and 59, This fuzzy era of 18footers shared names of caravelle , globester, wanderer, traveler, comet, pacer... The names might be CA and OH differences?
'62 appears to be the first 19 foot GT.
19foot 1964 is first year of reputed model standardization, CA and OH floor-plans matched. Last year of Door-in-Door.
'65 became a 20footer (20' 8”), relinquished Door in Door to stacked side lite window right of entry door. Hence forward, GTs always had a small stack window right of door.
65/66 were sisters, both had wet-baths, but the '66 got the beautiful new Corning/Philips curved glass. Today, everything is available to restore these windows to original.
The 67/68 GTs were stretched to 20' 11” and shared the same “luxurious” new bath design with all bigger trailers of 67/68. Comparatively, the nicest bath yet, perhaps ever. Two floor-plans, Twin or Double.
1969 21footer was the year of modernized shell change. GTs got longer, wider, heavier until disappearing after 1977, and have yet to resurface.
Your damaged refrigerator roof vent is on the curbside directly above the stacked refrigerator access doors to the left of entry door.
Your water heater door is pretty hammered, but save it.
Keep posting photos, and good luck...
ALUMINUMINUM is offline   Reply With Quote
Old 03-25-2015, 07:58 AM   #24
NO HUMBLE OPINION
Images
Name:	'49 GT floor plan low res.jpg
ID:	234905   Click image for larger version
Name:	Low Res Globe Trotter.jpg
Name:	Globe Trotters Rule.JPG
ID:	234907   Click image for larger version
Old 03-25-2015, 01:12 PM   #25
M.C
MIAMI , Florida
Well this is starting to make a bit more sense now, trailer length is actually 20'11" and not 21 FT as I said previously. Ref vent is on curb side, plumbing for kitchen sink vent is in between window and fridge access doors, curved window right to entrance door is 17 by 20 or close to that, round marks from old lights are still there maybe it can help a little to identify it.
Old 03-25-2015, 01:34 PM   #26
M.C
MIAMI , Florida
Some Interior pics
ID:	234913   Click image for larger version
ID:	234915   Click image for larger version
Old 03-25-2015, 01:36 PM   #27
M.C
MIAMI , Florida
Back pics and storage access?
ID:	234917   Click image for larger version
Old 03-25-2015, 01:39 PM   #28
M.C
MIAMI , Florida
I found more letters on A frame right under the power tow cord
Newbie to airstream world Dreedy650 Dollars & Cents 10 07-26-2014 11:08 PM
Brand Spanking Newbie to This Whole New World! vkettell Member Introductions 25 07-30-2009 05:31 PM
The Best Airstream in the World myboyburt Our Community 12 09-21-2006 12:45 AM
Camping World's Airstream MH makeover Bob66789 Airstream Motorhome Forums 9 11-08-2005 06:50 PM
Newbie to the Argosy world!!! 76ArgosyDave All Argosy Trailers 5 05-26-2005 10:38 AM
