Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Globetrotter > 1965 Globetrotter
Old 10-19-2002, 08:47 PM   #1
buckmaster's Avatar
Profile:  1965 20' Globetrotter
1970 31' Sovereign
Newport , Oregon
Main Door
Well the first project I under took was to fix a broken door frame. this was the internal door frame of the main door. It was broken where the door handle goes and above and below the hinge. I used some square aluminum tubing to reenforce the break then epoxied and screwed it all together, Now the door will close but the Main hinge is worn I'm not sure how I will deal with this replace it? or work up some shims? any suggestions would be helpful.
buckmaster is offline   Reply With Quote
1970-1977 Main Door Lock gvanman Doors & Locks 52 10-17-2008 11:22 AM
Entry Door Questions sladew Doors & Locks 22 12-13-2003 08:43 AM
Door Hinge Adjustment Cracker Doors & Locks 11 11-02-2003 08:24 AM
Main door problems Silvertwinkie Our Community 8 03-03-2003 12:46 AM
