Old 12-29-2014, 01:26 PM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Hanging motorcycle rack on rear bumper
Sure seems like a bad idea to me...
1966 Globe TROTTER AIRSTREAM
BambiTex is offline   Reply With Quote
Old 12-29-2014, 02:10 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Bad, BAD idea..
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-29-2014, 02:13 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I wouldn't do it... wayyyy too much weight
Whats good for me may not be good for the weak minded.
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 12-29-2014, 02:14 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I'm thinking the ad probably should have read "scooter rack", not motorcycle rack, but still a couple of scooters would still pack a fair bit of weight and the stress on the trailer frame would be a lot.
Epic bad idea.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 12-29-2014, 02:36 PM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Might as well take a sledgehammer to the trailer right now and save yourself some time totally destroying the frame.
Bob Martel
WBCCI# 5766
Old 12-29-2014, 02:50 PM   #6
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Maybe the trailer needs to be totaled so the finance note can be retired.
from the AIRphone
Old 12-30-2014, 06:39 AM   #7
Chelsea , Michigan
Images: 12
I've helped to take apart an Airstream for a "frame off" restoration. If people knew how these things were built, they would never hang anything off the back frame or bumper of an Airstream. They are simply not designed to take the load.
Bob Martel
WBCCI# 5766
Old 01-12-2015, 09:21 AM   #8
Rucksta's Avatar
1968 20' Globetrotter
Grants Pass , Oregon
Why is that a bad idea?
'68 Globetrotter "Tonto"
Rucksta is offline   Reply With Quote
Old 01-12-2015, 09:34 AM   #9
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Potential stresses on the trailer frame may be more than the design allows. Reinforcement of the frame may be necessary.
Adding a small motorcycle/scooter to the back will reduce the hitch weight. Higher potential for sway if hitch weight < 10% of gross weight.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 01-12-2015, 09:41 AM   #10
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The heavy weight behind the bumper can work like a pendulum hooked to your truck bumper, hard to stop any sway if it starts. Our Airstream Owners Manual warns against it.
Doug and Cheryl
Old 01-12-2015, 09:54 AM   #11
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Airstream frames are lightweight. Airstreams are constructed somewhat like an airplane, it's called "semi-monoque" which basically means that the ribs body and frame work together to support the weight of the Airstream. In SOB's they build a big honkin' frame that is the sole structural member - the walls and floor just rest on the frame. This "modification" has put a lot of weight on the very rear end of a weak frame. Unless the frame was totally replaced with a frame like an SOB, the frame is going to break somewhere between the axle and the motorcycle rack. Additionally the whole balance of the Airstream has been thrown off. Too little weight on the ball for starters and
then there is the dynamic weight. Now go down the road and hit a pothole and the weight on the far end of the frame does a whip crack and bounces like it weighs 900 lbs.
See post 20 in this thread - learn this term "polar moment of inertia" and what it means. The tail LITERALLY wags the dog! There was one full sized 15 passenger van which had the body extended, but not the wheelbase, so that six or more passengers were behind the axle. When going around a corner at speed the rear end got moving so fast relative to the axles that the van went over on it's side and spewed passengers out onto the road. I'm pretty sure that's been redesigned by now.
http://www.airforums.com/forums/f238...a-32704-2.html
Old 01-12-2015, 10:26 PM   #12
Rucksta's Avatar
Interesting.
I reinforced my frame with 4" channel, from the axle back, distributing the weight and extending the stress/load points... I am quite certain (post #20, inclusive) most AS owners are going on experience (mostly of others) of the dreaded "tail/rear end sag", and other horror stories. I carry a Honda Trail 90 on my rear rack (mounts directly to each side of the frame, through the bumper) with ABSOLUTELY NO PROBLEM, What-so-ever...
I also have a weight distribution hitch with sway control, so maybe I'm just incredibly lucky? Or, maybe it's time for those who aren't 100% POSITIVE of the possibilities, options, and capabilities of these beauties to stop scaring others with hear-say?
Either way, I appreciate the forum for what it is and wish everyone a safe and happy AS experience.
Old 01-12-2015, 11:01 PM   #13
Rucksta's Avatar
Mis-typed and couldn't edit after 30 minutes of posting...
Welded-in 3" x 1 1/2" square tube from axle to bumper.
(Hell, it may have been 4"x2", now I'm gonna have to measure because it's driving me crazy).
Ruck
Old 01-12-2015, 11:11 PM   #14
Rucksta's Avatar
Pics...
ID:	230314   Click image for larger version
ID:	230316   Click image for larger version
Rear Bumper Hitch Receiver for Bike Rack Seaheart Towing, Tow Vehicles & Hitches 3 07-25-2012 12:19 PM
Need help with motorcycle rack selection Mellen60 Towing, Tow Vehicles & Hitches 4 05-25-2012 09:04 AM
'95 36' Cutter rear bedroom liner hanging brodjeaw Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 01-15-2011 09:10 AM
Bike Rack Rear Bumper GJ Excella 1987 - 1989 Excella 56 03-19-2010 08:39 PM
Safari Sport bike rack..where is the rear bumper? Hickey 2008 Safari SE 2 08-25-2008 03:42 PM
