01-12-2017, 03:49 PM
1963 19' Globetrotter
Seattle
Found a set of levelers under trailer
Finally warming up a bit and started going thru trailer - Found this set of 4 levelers mounted under the trailer - looks like a wrench tool attaches to ends and drops them down.
anyone familiar with these?? were they an Airstream option?
1968 22' Safari - All Original
01-12-2017, 03:53 PM
1965 26' Overlander
Tulsa
, Oklahoma
Those are original, yes you need a socket to raise or lower them.
01-12-2017, 04:04 PM
1979 23' Safari
1954 29' Liner
Orange
They are stabilizers and not levelers. Do not use them to level your trailer, it will cause stress and make opening and closing the main door difficult if not impossible.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
01-12-2017, 04:20 PM
1986 31' Sovereign
Miami
If you carry a battery-powered drill/driver, such as a Dewalt, you can buy a socket for it at Camping World and run the levelers up and down a lot easier that the standard handle.
As previously noted, these are "stabilizers" - run them down to the ground and then a skosh more turn. You are not trying to lift the trailer, only trying to put down four rigid support points on the corners to minimize rocking and rolling as you move around the trailer.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
01-12-2017, 05:22 PM
Biloxi
, Mississippi
Please do not try to use them to level the trailer. Possible expensive damage might be incurred.
MICHAEL
01-12-2017, 07:30 PM
Seattle
thanks all - i meant to describe them as a "supports" for the trailer.
i'm going to oil up the threaded rods prior to using them.
really nice feature to have
01-12-2017, 07:40 PM
1987 Avion 34W owner
Good Ol'
, USA
Yes, they are a nice feature. They are still available new if any of yours are too far gone.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
01-13-2017, 01:23 PM
2012 23' FB International
Woodstock
, Ontario
They originally would have been lowered and raised with a speed wrench that was supplied with the trailer. I have one for my '96 that I use for the stabilizers and the equalizer jacks on the Hensley. Also had one with the '89 and the '94 Award...all original equipment
In my experience you can use the stabilizers to raise about 1/2 inch on one side with not too much stress on the body. Just helps to bring the last little bit of leveling for comfort (and the reefer; although the new units are not so sensitive to "level").
JCW
01-13-2017, 02:16 PM
1976 31' Sovereign
Oswego
Any socket does not have to come from Camping World. Buy several cheapest can find and adapter to fit cordless drill, other end fit socket. There isn't any stress on socket plus will lose several over time as they will fall out of drill when walking around 4 levelers If not much need for cordless Harbor Freight has good 18 volt and Wal-mart has good black and decker 18 volt, both 3/8 drive lots of torque plus price very good. you will not need exp. drill. I have both only 1 went bad when dropped from roof. I quit buying exp. now goes bad throw away. I believe socket size is 3/4 trailer not avlbe. to check size.
01-13-2017, 02:20 PM
1976 31' Sovereign
Oswego
Use wd40spray or dry silicone spray not oil will collect dirt.
01-13-2017, 04:45 PM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
Bill
I concur.
01-13-2017, 05:48 PM
St. Louis
, Missouri
What year is the trailer? '66? If so, they didn't use a cordless drill to raise and lower the stabilizers. There was a handle with a socket on one end. You raise and lower just as you would the jack on your car. My trailer is '89, and they were still using manual handles.
Would stabilizers be an option on an AS? I supposed they would be standard equipment, no?
The Morgans
1989 Avion 34VB
01-13-2017, 06:38 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
I like to have a wrench even if I use a drill & socket most of the time. Never know when a drill might stop working.
Originally those stabilizer jacks would have had a circular base pad on them. You might want to add them back on. Both are available here:
http://norcoind.com/bal/products/con...es.shtml#25025
Alan
01-13-2017, 06:45 PM
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
I've tried a variety of lubricants and the two that have worked best for me are dry graphite lube and dry silicone lube. Anything that remains relatively wet (including WD-40 IMO) will attract dirt.
The graphite and silicone products go on wet but dry to the touch in just a matter of minutes. For me, they last a few months and I just reapply periodically.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
01-13-2017, 06:52 PM
1967 22' Safari
MILAN
stabilizers
Alluminati, Stabilizers were an option not standard equipment back in the sixties. Yes, they did use a crank handle with the correct sized socket on the end to drive the stabilizers. But these days a cordless drill does three things for you.... 1) Ease of operation, 2) Ease of storage. Then 3) Cordless can be used for other work on TV or Trailer. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
01-13-2017, 07:15 PM
2011 30' Flying Cloud
East Jordan
, Michigan
Looks like the round pads that contact the ground are
missing. They are important. You will have to check
out a photo of a complete stabilizer online. Good luck!
01-14-2017, 08:50 AM
1968 22' Safari
NorCal
There's a good photo of the stabilizers with the pads here http://www.airforums.com/photos/show...00&userid=3961
My trailer has the stabilizers but no pads - I did however find them on Amazon Prime for not much more than Campingworld. I didn't know that the stabilizers were supposed to have the pad/foot! Glad to find the info here!!
Gratitude for all there is and all there isn't!
Photos of our gal.
WBCCI #19233
01-14-2017, 01:06 PM
Seattle
thanks for the info!!
