Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Globetrotter > 1965 Globetrotter
Old 06-16-2008, 12:30 PM   #1
Dr JJ
Profile:  1965 20' Globetrotter
Unadilla , Georgia
Electrical problem
Hi All, I would like to know how to tell if the Constavolt conveter is working right or not on my 65 GT. All lights are working except the overhead and the light under the cabinet up front when on shore power (120v). I'm not much of an electrician but it seems I have a short somewhere. Also, I blew fuses on the little panel underneath the bed when I tried to install the new battery I just purchased. There are two fuses there and both are blown. Anyone ever have this problem? Any help will be appreciated.
Jerry (getting really hot in GA)
Dr JJ is offline   Reply With Quote
Old 06-16-2008, 03:03 PM   #2
DEITZ645
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 16
Dr JJ,
You can use a multi-meter to see what your converter is outputting at the terminals.
As for replacing batteries; Whenever I hook up or disconnect the batteries I make sure that the 12 volt master disconnect inside the trailer is OFF. I take extra special care to make sure the battery wires aren't touching anything that may cause an arc, spark, and short. When hooking up a battery I always attach the positive terminal first and then the negative. Reverse that when disconnecting a battery; remove the negative wire and then the positive. This will keep the arcing and sparking down to a minimum.
Hopefully somebody else can give you a lead on your two non-functioning lights. I am assuming you have already checked to make sure the bulbs aren't burnt out and they are making good contact with the socket. The multi-meter would also come in handy troubleshooting to see if you are getting 12 volts at the non-functioning lights.
Good luck and keep us posted.
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package
1987 34' Excella 1000
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
AIR #14487
WBCCI #7429
DEITZ645 is offline   Reply With Quote
Old 06-16-2008, 03:08 PM   #3
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
My fuses are AGC 40s (American Glass Company)
Originally Posted by Dr JJ View Post
... There are two fuses there and both are blown...
Were the fuses BHF's?
Big Honking Fuses, in Airstreams, start at 40 amps. Those fuses are sometimes categorized as "BFF's" (sorry, can't seem to remember what it stands for )
Anyway, if both BHFs are blown, it usually means someone installed the battery backwards at least once.
Tom
Old 06-17-2008, 12:13 PM   #4
Dr JJ
Unadilla , Georgia
Thanks Guys, I plan to get back out on the GT late this afternoon. Will do some more checking as you have explained. Gee Whiz its 98 degrees on my shaded deck right now (2:06pm). I'm having to kinda take it slowly now after back surgery and a bout with kidney cancer and being past retirement age does not help either!! I will probably have to take the GT to bro-in-law as I don't know how to operate a multi meter even though I read the instructions ... as I said I'm not very knowledgeable in electricity. Thanks again
Jerry
electrical problem kent osborn 1966 - 1968 Safari 3 09-27-2003 05:30 AM
AC electrical problem lbf78SvgnInt31 Electrical - Systems, Generators, Batteries & Solar 2 07-26-2003 06:44 PM
Electrical Problem NASCAR345 Airstream Motorhome Forums 15 03-13-2003 06:23 PM
HELP! Electrical problem FranceyS Electrical - Systems, Generators, Batteries & Solar 4 11-11-2002 05:27 PM
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 22 08-22-2002 09:47 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
