We had a new black tank box made. The Thetford flange was solvent welded on. Attach a Thetford water valve 08708. Then attach a nernco 3 inch socket to pipe. Attach a straight pipe sanitary tee outside the box. You can run a gray water line outside the box
Is the rib to the left of the water tank suppose to hit the outrigger?
Deb
