Old 07-06-2007, 09:32 AM   #1
gypsymoth's Avatar
1969 21' Globetrotter
1972 27' Overlander
Fort Walton Beach , Florida
'69 Globetrotter - how many tanks do you have?
Hi,
I have a 69 GT that had her pipes and tanks removed before I bought her.
My dilema: I don't have the Owner's Manual with schematics. A kind person sent me a copy from their old manual of the drainage system. However, this schematic shows ONE holding tank (plus fresh water tank). Mine came with TWO (used and identical) holding tanks that fit where the ONE is in the schematic.
I'm not sure if I have all the pipes, so do I put it together with ONE holding tank or TWO?
Any current or former 69 GT 21' owners: How many holding tanks do you have?
Thanks for any help!
Colleen
gypsymoth is offline   Reply With Quote
Old 07-06-2007, 09:59 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Airstream did not start putting in 2 tanks (Black and Grey) untill the mid 70's. You trailer came with one tank, but most likely was modified by a PO. The original layout would have the toilet empty into the black tanks and everything else (grey water) run out of the trailer on to the ground. Most places do not allow you to dump grey water on the ground and this may have been why the trailer was modified. I would stay with the two tank setup. You should also have two dump valves. This would be a much perfered arangement.
Richard
Old 07-06-2007, 10:39 AM   #3
gypsymoth's Avatar
1972 27' Overlander
Thank you! That makes sense.
Old 07-06-2007, 03:41 PM   #4
soldiermedic's Avatar
Florissant , USA
I have a tank out of my 68 safari that you can use if you want another tank for the trailer.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 07-07-2007, 02:36 PM   #5
gypsymoth's Avatar
1972 27' Overlander
Wow! That's nice of you! What size and type is it?
Old 07-07-2007, 02:40 PM   #6
Florissant , USA
Black tank from a 68 safari....pretty big.
Goto the inlandrv website for parts to see what it looks like since I dont have a picture handy.
Steve
Old 07-07-2007, 11:34 PM   #7
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Hi GypsyMoth;
Did you figure out your tanks yet??
If you do not have any tanks then you have a clean canvas. However be sure that your tanks don't sit too low in the belly for ground clearance - and remember the shower drain will need to drain down into the wash water tank.
Our 69 did only have a blank tank under the toile (stepped portion of the wet bath).
If you are looking for tanks - try rvsurplus they have really reasonable new tanks made to order as well as many sizes of stock tanks, shower pans and bathtubs (although not with the curve).
Are you changing the original layout???
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 07-10-2007, 06:35 PM   #8
gypsymoth's Avatar
1972 27' Overlander
I'm not sure what is best - to do with the tanks. All of my plumbing has been removed. I bought her in pieces.
I would like her to be the original layout inside. But that needs to be put back together correctly too. I have been looking at photos of other GT's to see what she should look like. Your Moonbeam is the layout mine should have. She looks great!
Another reason for aluminum tanks rochleau Our Community 4 09-03-2002 06:30 PM
LP Tanks Craig LP Gas, Piping, Tanks & Regulators 6 08-22-2002 08:43 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
