Old 07-18-2016, 09:30 AM   #1
1966 20' Globetrotter
Norcross , Georgia
66 GT Penguin II AC Install In Rear Vent Opening?
I am a relatively new owner - we purchased a mostly original 1966 Globetrotter in March. I'm putting the finishing touches on installing an Atwood tankless water heater and now ready to install an AC unit.
I've checked with the AS factory and understand that the original wiring should be 71 inches back from the front rib. There are forum threads about installing AC units on freshly-cut holes (near the center of the GT roof but I would like to install my unit in the existing hole for the rear vent.
My plan is to buy a new Dometic Penguin II unit and rent scaffolding to help with placing it on the roof. (Iíve been quoted as much as $600 to install the unit at a service center so I am willing to give it a try)
Have any of you Globetrotter owners succeeded in installing an AC unit in the original rear vent opening and using the factory supplied wiring? If so, were you also able to install a drain line without too much trouble?
I would appreciate any shared comments, photos, diagrams, etc.
Aircody is offline   Reply With Quote
Old 11-27-2016, 06:49 AM   #2
Norcross , Georgia
Update on A/C installation
I decided to go with mounting the Penguin II on the location that Airstream recommended. Just in time for the weather to turn cool so I don't need it right now. I still need to route the wiring to the thermostat so that it is hidden - it is duct-taped to the ceiling for now...
Old 11-27-2016, 07:05 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Run the wires through some 3/8" pex, so it won't get pinched or chafed. It will also make replacement later much, much easier, if ever needed.
BTW, you'll find you are going to need something to keep the roof and ceiling from being crushed together. I've made up a kit to frame the hole out, which is available at the dealership where I work.
Penguin I to Penguin II drain pan? HiJoeSilver General Repair Forum 1 05-25-2015 04:51 AM
Dometic Penguin 2 install tech question. seldencove Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-25-2014 05:11 PM
Penguin install cwf Furnaces, Heaters, Fireplaces & Air Conditioning 30 07-21-2013 04:50 PM
How do I install a large opening for a mobile bar? gmckissock Windows, Doors, Locks & Vents 6 04-17-2011 10:32 AM
