Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Globetrotter > 1965 - 1969 Globetrotter
Old 01-12-2015, 09:24 AM   #161
Rucksta's Avatar
1968 20' Globetrotter
Grants Pass , Oregon
Originally Posted by thumbelinadj View Post
Hi, I am happy to meet my fellow AS owners. Live in North Seattle. Purchased last week out of Gold Beach, OR. It's in great shape. Known for my great vision, lacking skills and tools. Some work I will do on my own, other will be hired out.
The first thing I want to do is fix the hitch and tongue. Next would be electrical and wheels/tires. Guidance on RV repair experience. People you may have dealt with.
Thank you!
LOVE IT!!!
Ruck
'68 Globetrotter "Tonto"
Rucksta is offline   Reply With Quote
Old 01-16-2015, 10:34 AM   #162
GlamperGirl
The waiting waiting waiting. Frame still at sandblaster. Then welding takes about forty hours he says.
I hate not doing anything. May have to start sanding and prepping the interior skins. Or polish window frames this weekend. Go Seahawks!
thumbelinadj is offline   Reply With Quote
Old 01-16-2015, 07:18 PM   #163
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
What's a Seahawk?
David
Old 01-17-2015, 06:54 AM   #164
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
Did you have a lot of outriggers and crossmembers to replace on your frame?
If you have to clean the wall panels and they are the vinyl "wallpaper" coated type that mine are, the best stuff to clean them with that I found was Marine Clean. That stuff is awesome. Diluted 1 part MC to 2 parts water it was able to clean the filthy area the was behind the refrigerator vent scoop. It now looks brand new with very little elbow grease .
It's great to see another woman tackling one of these silver dreams. I am enjoying your thread. It's nice to see someone getting things done while I wait in the frozen north for Spring to get mine started again.
Dingo Girl is offline   Reply With Quote
Old 01-17-2015, 02:29 PM   #165
indy's Avatar
1962 22' Safari
kansas city , Missouri
Images: 22
Love watching your progress, I am Derald from FB, enjoy your journey.
indy is offline   Reply With Quote
Old 01-17-2015, 06:43 PM   #166
GlamperGirl
Dingo dear lady, thank you thank you! There was rot on the floor but no cross member issues. The frame is being reinforced and fitted for my slim grey water tank. The experience is a one of a kind indeed.
Old 01-17-2015, 06:44 PM   #167
GlamperGirl
And oh I forgot GO SEAHAWKS!!
Old 01-18-2015, 05:35 AM   #168
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Does your doggy chase these seahawks around? Barking at them will make them go!
I think you should clean up window frames while you are watching the seahawks go. These is no rest for Airstream renovators! I continue to spend hours and hours standing behind my polisher getting covered in black dust. It's such a boring job! I've got 25 hours in it already and many, many more hours to go.
David
Old 01-18-2015, 10:05 AM   #169
indy's Avatar
1962 22' Safari
Images: 22
As you progress with your GT things you may want to consider, I ran water proof LED strip lights with a remote under the trailer and LED inside our cabinets and wow what a difference, call me crazy I also added LED in the medicine cabinet in the bath.
Old 01-18-2015, 09:34 PM   #170
GlamperGirl
'65 GT 20' my winter project
SuperBowl. Yes David. Go Seahawks. :-). Derald that was some game!
Old 01-19-2015, 04:49 PM   #171
GlamperGirl
Trailer back. Welding starting. Removing steel at tongue. There was no drain at the tongue and water could seep in of course. The inside was incredibly thin at a each Y section where water pooled. Happens all time apparently on old tongues.
Old 01-19-2015, 04:50 PM   #172
GlamperGirl
Name:	ImageUploadedByAirstream Forums1421711391.516789.jpg
ID:	230748. Where water pooled and lots of pitting
Old 01-19-2015, 04:51 PM   #173
GlamperGirl
Name:	ImageUploadedByAirstream Forums1421711439.844017.jpg
ID:	230749 cut out this section and you can see all that rust inside Click image for larger version
Name:	ImageUploadedByAirstream Forums1421711473.728505.jpg
ID:	230750Click image for larger version
Name:	ImageUploadedByAirstream Forums1421711490.314218.jpg
ID:	230751Click image for larger version
Name:	ImageUploadedByAirstream Forums1421711504.815824.jpg
Old 01-19-2015, 05:01 PM   #174
2007 22' International CCD
Rest of it doesn't look too bad?
Old 01-19-2015, 05:15 PM   #175
GlamperGirl
Nope not bad. I love using that plasma cutter. Dang I might like welding
Old 01-19-2015, 07:35 PM   #176
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Welding is an acquired skill. Just takes quite a bit of practice to get the metal to flow the way you want it too. But I'm sure you can learn. The frame looks much better now than before. Sand blasting saved you a bunch of time wire brushing and a better result. Fix the weak spots and you're starting the rebuild!
I hear the seahawks did in fact go and are now heading to the big bowl or something like that.
David
Old 01-19-2015, 07:40 PM   #177
Just be careful. Old-style arc welding is how I got some scars a bit close to certain tender bits.
Safety first, and make sure your welding tools are in good repair. Insulated handle slid off the stinger when I was trying to free a stuck rod. Rod got red hot, then broke loose and hit me end first in the thigh. Note: A) flesh sizzles like awful, and B) an open circuit welder will shock the heck out of you. I should have been wearing a heavy apron. Nuff said.
Modern wire-welding hardware is much easier to use, but you still gotta wear all the safety gear. ☺️
Old 01-19-2015, 10:13 PM   #178
1965 20' Globetrotter
Sacramento , California
Images: 16
Thumbelina, here's a link to a thread I was fortunate enough to receive today from a member about fixing up and installing windows...thought you might like to see what she did as I see you are getting ready to work on your windows too. I Am so enjoying watching your progress. It's like gazing into the looking glass for me.
http://www.airforums.com/forums/f109...-78136-30.html.
(Maybe you have already seen it)
Jayne
Jayne & Brian
Luna, 1965 Globe Trotter 20’ Twin
2018 Toyota Sequoia
jakes_mama is offline   Reply With Quote
Old 01-19-2015, 10:57 PM   #179
GlamperGirl
LED is a must do Indy!
I pulled the rest of the left over wire out today. We are bare metal.
The welder Matt managed to accomplish a few things in four hours of work today on the frame. Thank you Airstream Angel for the Millermatic 251 and the auto lift
Name:	ImageUploadedByAirstream Forums1421733325.422975.jpg
ID:	230757   Click image for larger version
Name:	ImageUploadedByAirstream Forums1421733352.421509.jpg
Name:	ImageUploadedByAirstream Forums1421733373.974143.jpg
Old 01-19-2015, 10:59 PM   #180
GlamperGirl
Name:	ImageUploadedByAirstream Forums1421733554.069610.jpg
1963 Globe Trotter Winter Project Chrjbenn 1960 - 1964 Globetrotter 15 05-28-2013 05:23 AM
1968 Airstream Sovereign - Needs restoration - Great winter project! eBay Watch Airstreams on eBay 0 10-02-2011 04:30 PM
Winter project time toastie Electrical - Systems, Generators, Batteries & Solar 3 11-03-2006 04:34 AM
