Old 12-14-2014, 07:26 AM   #85
GlamperGirl
While reading up and watching videos in windows I learned my 65 windows slide out horizontally from the outside. Ugh. One by one they al are coming out. Just a mess. Deciding my containment and work space to set up a station for that work. The stripper residue containment below the sawhorse table and disposal conundrum.
thumbelinadj is offline   Reply With Quote
Old 12-16-2014, 07:44 PM   #86
GlamperGirl
Ceiling panel. So is this seamed? How to remove by myself? Same with end caps. Do they really go out the door Click image for larger version
Name:	ImageUploadedByAirstream Forums1418784226.805426.jpg
Old 12-16-2014, 07:48 PM   #87
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Originally Posted by thumbelinadj View Post
Ceiling panel. So is this seamed? How to remove by myself? Same with end caps. Do they really go out the door Attachment 228778
The "seam" strip stays up there when you take each ceiling panel down. Just drill out every pop rivet you see & lower the panel on the curbside, then do the same on the streetside. Yes everything fits out the door, even the endcaps. Both of these jobs require at least one extra pair of hands.
Colin
Colin H is offline   Reply With Quote
Old 12-17-2014, 12:54 AM   #88
GlamperGirl
The PO really loved to paint the panels and the seam was tough to pry off. That seam strip is so shiny pretty. Leaving the end caps on until I am forced to remove them with help. The one in the rear bath is just hanging on via a few rivets and those plumbing pipes. My Sawzall gave out because I forgot to charge the battery, but I am so close to getting that #%* base off the toilet sat on. I needed an IMPACT driver for the screws on that toilet ring!
The garage is really filling up. Have the wood to build the gantry as you see on the floor. Axel and brakes, the flooring MDO. Hehr supplies are all here. Two big tables on saw horses have the window frames and the panels laid out. I forgot to check the size of bolts for the gantry on the plans I found on the forum. At least I have the wood! Do I put wheels on them? Need to read up and determine what to order for the proper rivets.
Tested the rivet removal tool from VTS on the underside. Works great with the ones with the holes. The capped ones I ended up YouTubing a video. Found a punch. Carefully tapped on them. Love to slide off that cap. sucks.
Managed to slide out my rear window. Not too easily. Used PB Blaster and a mallet. It felt good - six more to go.
I am learning so much. Rivet removal and window removal over the weekend is planned.
My friend thanked me for treating his shop with respect. I do like a clean workspace and he appreciates that. Being that I have never tackled anything like this, I am calm and ready to keep going. I feel accomplished every time I drive away.
ID:	228782   Click image for larger version
ID:	228784   Click image for larger version
Old 12-17-2014, 05:33 AM   #89
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I have the "rivet removal tool" also. The tool is designed to locate around the base of the 5/32 diameter rivet head. The tool is spring loaded. Tighten the tool in your drill. Pull on the tool and see how it gets longer and extends beyond the drill bit. Now locate the tool over a rivet. Push the tool down around the rivet head and hold it tight with one hand. Now start the drill and drill out the rivet right on center. The drill will spin inside the tool. The outside of the tool does not spin. No need to center punch the rivets, which is hard to do as you have found. The tool locates the drill right over the center of the rivet. Presto! Rivet be Gone! Booohahaha!
The pop rivets have a hole in the middle. You don't need the tool for those. They are used a lot in the interior of our Airstreams, and the belly pan. Pop rivets are "blind" rivets. Buck rivets are solid, strong, but take two people to install. One on the outside with the riveting tool, and one on the inside with the "bucking bar".
You probably knew all this already. Just trying to be helpful...
Yes, a clean shop is a safe shop. There is less chance of slip or trip. Think safety all the time. "How can I get hurt doing this activity?"
I'm scraping the sealant off my roof vents. I think it was factory original in 1966. It wasn't silicone, but a good old fashioned calk. Now I can seal them up again. I really like the vents in our old trailers. It's neat the way they work.
David
Name:	1412 Vent Front Sealant Shot.jpg
Old 12-19-2014, 05:15 PM   #90
GlamperGirl
'65 GT 20' my winter project
Most of the insulation is out as well as the old electric. All copper is gone and we are ready tomorrow to begin working on the underside to take rivets out. Have two workers coming to assist. Today I was able to ease my bathroom end cap down by myself. Storing the caps are my worry Suggestions on how to lay them on my floor? On wood or towels or what? Click image for larger version
Name:	ImageUploadedByAirstream Forums1419034508.308042.jpg
ID:	228897Click image for larger version
Name:	ImageUploadedByAirstream Forums1419034524.391474.jpg
ID:	228898Click image for larger version
Name:	ImageUploadedByAirstream Forums1419034545.327617.jpg
Old 12-19-2014, 05:44 PM   #91
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Most of the insulation is out as well as the old electric. All copper is gone and we are ready tomorrow to begin working on the underside to take rivets out. Have two workers coming to assist. Today I was able to ease my bathroom end cap down by myself. Storing the caps are my worry Suggestions on how to lay them on my floor? On wood or towels or what? Attachment 228897Attachment 228898Attachment 228899
Just lay them on the floor. They'll be fine.
Colin
Old 12-19-2014, 06:49 PM   #92
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Wow! You're making good progress. Your subfloor doesn't look too bad. It won't be long before you reach the magic "milestone" when you actually put the first thing new and improved on the trailer. What will that be? Usually it is a new or repaired piece of the frame.
David
Old 12-19-2014, 11:55 PM   #93
GlamperGirl
Thank you! I'm ready for the weekend.
Old 12-20-2014, 06:06 PM   #94
GlamperGirl
The hire I made was awesome. Ron took a chisel and made a nice edge for me on the grinder and taught me how to pop the rivets. I was a machine. Every window and all around the bottom I went to town. Removed a few. It's going to be interesting cleaning these windows up.
He then dug into the belly pan. The man likes to get dirty. Guess what he has an Avion he restored!Click image for larger version
Name:	ImageUploadedByAirstream Forums1419124000.533047.jpg
In addition a young man (32 is in my world) showed up to "apprentice". We will see if he comes back. I'm excited for his plan to quit work at Amazon after 8 years and travel with his wife and five year old for a year in their airstream ( yet to be bought)
I saw the frame!
Received many nice gifts for my 52 years young birthday tomorrow as well. I had a good day.
Name:	ImageUploadedByAirstream Forums1419123679.859845.jpg
ID:	228952Click image for larger version
Name:	ImageUploadedByAirstream Forums1419123699.224634.jpg
ID:	228953Click image for larger version
Name:	ImageUploadedByAirstream Forums1419123715.960499.jpg
ID:	228954Click image for larger version
Name:	ImageUploadedByAirstream Forums1419123733.932006.jpg
Old 12-21-2014, 02:29 AM   #95
GlamperGirl
Can't make a final decision and need input.
Shell lift via chains or straps?
Do I run chain and wrap towels though vents or my windows?
Do I attach a 2x12 to ribs and fashion something with that?
Thank you,
Old 12-21-2014, 07:08 AM   #96
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Happy Birthday! Yes, there is a frame down there somewhere. I like that the factory paint is still on a lot of it. You can sure see where the frame has sat in water. Some folks, including me, drilled small drain holes in the belly pan so the water doesn't get too high and may find its way out. My 86 must have had 2" of standing water in the rear of the trailer judging from the rust line on the frame.
I've never lifted a shell off so I am of no help. Inland Andy talks about the timber and jack method where no hoist is used. Others lift through the roof vents. Either chain or straps would be enough strength to lift an Airstream body. It isn't all that heavy.
David
Old 12-21-2014, 06:55 PM   #97
GlamperGirl
Thank you had a nice day
Old 12-24-2014, 04:30 PM   #98
GlamperGirl
I'm struggling with making the cuts on the front panels. They are curved under. So I destroy them and have them remade? Click image for larger version
Name:	ImageUploadedByAirstream Forums1419463769.896446.jpg
ID:	229158Click image for larger version
Name:	ImageUploadedByAirstream Forums1419463789.195668.jpg
ID:	229159Click image for larger version
Name:	ImageUploadedByAirstream Forums1419463800.116402.jpg
ID:	229160Please advise next steps to remove them.
1963 Globe Trotter Winter Project Chrjbenn 1960 - 1964 Globetrotter 15 05-28-2013 05:23 AM
1968 Airstream Sovereign - Needs restoration - Great winter project! eBay Watch Airstreams on eBay 0 10-02-2011 04:30 PM
Winter project time toastie Electrical - Systems, Generators, Batteries & Solar 3 11-03-2006 04:34 AM
