Old 12-08-2014, 07:53 PM   #71
2007 22' International CCD
I usually determine "time to step back" by the number of times small hand tools go flying from frustration. 😄
KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
Old 12-09-2014, 01:43 AM   #72
GlamperGirl
Here is what quiet time did for me... Wood interior. solar. I'm going to live in it one day Click image for larger version
Name:	ImageUploadedByAirstream Forums1418114550.878821.jpg
thumbelinadj is offline   Reply With Quote
Old 12-09-2014, 03:58 AM   #73
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Your doggie has a very cute face! Nothing better to make us feel good.
I made my bath remodel plans on a piece of paper, a ruler, used 1/4" per foot scale, and started fitting in the vanity, closet, shower, toilet all to scale. I actually drew the outline of the rear floor space on a sheet of paper, and then made copies of that so I could more quickly create variations of my layout. I fussed a long time about the height of the vanity. My rear window is about 29" off the floor. That's pretty low for a vanity counter top. My 86 has a more normal 31" vanity height. I went with the 29" height as I really didn't have a good alternative. The story is Wally liked a big rear window so you could see through the trailer in your rear view mirror. But I think it's silly to have a big window in a bathroom.
I kinda wish I had forgone the shower stall. It takes a lot of room, but it's still too small. Our trailers are small, and sometimes we try to cram too much into them. I think comfortable seating and comfortable sleeping are the top priority.
The planning stage is one of the most fun aspects of the project. Creative. Just make sure you build a special place for your doggie in your new Globetrotter.
David
Old 12-12-2014, 03:48 PM   #74
GlamperGirl
What's the least disruptive way to remove this toilet. I have all rivetsClick image for larger version
Name:	ImageUploadedByAirstream Forums1418424470.863217.jpg
ID:	228480Click image for larger version
Name:	ImageUploadedByAirstream Forums1418424485.571909.jpg
ID:	228481 off and all fiberglass is loose Click image for larger version
Name:	ImageUploadedByAirstream Forums1418424447.625659.jpg
Old 12-12-2014, 06:54 PM   #75
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Toilets are usually mounted on a sealing ring mounted to the floor. There are two "T" bolts that are trapped in the sealing ring and pass through holes in the toilet base. Take a look at the toilet in your home and see the two bolts. Then see the photo of the toilet sealing ring I installed. in my Trade Wind over the black tank.
The potty in the picture looks different. It looks like a decorative "skirt" around the pedestal that might be concealing the mounting bolts. I almost want to take my screwdriver and pry or twist in the crack of that skirt and see if the plastic would separate.
David
Name:	1405 Bath Toilet Flange Installed.jpg
Old 12-12-2014, 07:12 PM   #76
GlamperGirl
I finally got that figured out thanks to you
Old 12-12-2014, 09:41 PM   #77
GlamperGirl
Comitted the purist sin, cracked fiberglass. Soooo I took a Sawzall to the rest. Amateur Hour I know. Sigh I was disappointed. It was fun though. Click image for larger version
Name:	ImageUploadedByAirstream Forums1418445667.817336.jpg
Managed to get the hot water tank, toilet, some copper out and the sink. For the life of me I can't disconnect from under the trailer the drains. Stuck stuck stuck
Grey water only had water.
Found my first petrified animal jammed in the pipe to the outside under the hot water tank.
The floor is bad. This is no surprise.
I video taped the whole underside and the rivets. Took pictures as well.
Removed two of my window frames. Some are painted.
Set up a sawhorse table for them. All of my Hehr supplies arrived today.
I'll be asking for details on how to remove the outside Rivets shortly. Will post photos or links to a site to review.
Gemma is so over this. But she loves running in the shop and on the property.
So appreciate your help and encouragement!Click image for larger version
Name:	ImageUploadedByAirstream Forums1418445595.569454.jpg
ID:	228501Click image for larger version
Name:	ImageUploadedByAirstream Forums1418445613.190482.jpg
Old 12-13-2014, 02:59 PM   #78
GlamperGirl
Still recovering from committing purist sin. Started removing panels. What is this black stuff? Click image for larger version
Name:	ImageUploadedByAirstream Forums1418507914.113279.jpg
ID:	228530Click image for larger version
Name:	ImageUploadedByAirstream Forums1418507926.395727.jpg
ID:	228531Click image for larger version
Name:	ImageUploadedByAirstream Forums1418507936.917644.jpg
Old 12-13-2014, 05:03 PM   #79
GlamperGirl
'65 GT 20' my winter project
Nasty silicone holding in the windows. They are painted over and a mess. What can I use to remove the silicone Click image for larger version
Name:	ImageUploadedByAirstream Forums1418515367.687120.jpg
Also this big old hole from the hot water tank. Am I able to get an instant heater to place in this spot or am I patching?Click image for larger version
Name:	ImageUploadedByAirstream Forums1418515431.404801.jpg
The blue tape I write on and take photos or for removal of panels.
Old 12-13-2014, 05:52 PM   #80
The black stuff is adhesive used to stick the insulation into the skin--probably tar.
The heater hole, if it is for a 6 gallon Atwood is actually a little short in height for a Precision Temp 550 instant HW heater. We love ours, and it fit in with little trimming, and the side flanges cover the rest of the hole. It can be ordered with a shiny aluminum door which really looks nice.
Silicon is tedious to remove mechanically and should no ever be used on aluminum. The acetic acid released when it cures corroded aluminum. All you can do is pick, scrape and cuss it off. Try not to launch too many hand tools 😄
KE4GNK/AE
Old 12-13-2014, 05:54 PM   #81
Oh, missed that. If the sealant has been painted over, and the paint is sticking well, it's NOT silicone. Paint won't stick to it. It's still tedious to remove...
KE4GNK/AE
Old 12-13-2014, 06:06 PM   #82
GlamperGirl
Silicone is on outside Click image for larger version
Name:	ImageUploadedByAirstream Forums1418519190.689465.jpg
Old 12-13-2014, 06:07 PM   #83
Ugh. Tedious to the max with some corrosion under. Sigh.
KE4GNK/AE
Old 12-13-2014, 06:47 PM   #84
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Your doggie does not look happy being a reindeer! But cute and amusing for us people. Your dog will find a way to get even, like chew your phone up.
I didn't shed many tears over the loss of my fiberglass bathroom pieces. I wasn't planning on a "restoration", I just wanted a functional bathroom. The shower was the hardest thing to fabricate, and I now wish I had given that more thought. Most campgrounds have a bath house. My trailer is small and the extra room consumed by the shower stall could have been better used. I don't plan on a boondocking trip across Africa.
Wait until you drop your belly pan. I think you will see access to your drain connection. I'll bet it just dumps into the drain manifold "downstream" of the black tank. Way back then, folks just dumped their gray water on the ground. The roof vent pipes you will need. The drain pipes you will re-plumb. There is nothing very valuable about 1 1/2 diameter ABS plastic pipe. Saws-All time!
The black stuff may be seam sealant Airstream used in a futile attempt to stop seam leaks. See if it doesn't follow exterior seams.
Silicone sealant on my trailer was picked off a little at a time. Maddening and time consuming. Some trailers have it worse than mine, but I sure got the taste of the removal process. The pictures show 30 minutes of pick'in and grin'in.
David
Name:	1411 Window Silicone Before.jpg
ID:	228546   Click image for larger version
Name:	1411 Window Silicone Removed.jpg
1963 Globe Trotter Winter Project Chrjbenn 1960 - 1964 Globetrotter 15 05-28-2013 05:23 AM
1968 Airstream Sovereign - Needs restoration - Great winter project! eBay Watch Airstreams on eBay 0 10-02-2011 04:30 PM
Winter project time toastie Electrical - Systems, Generators, Batteries & Solar 3 11-03-2006 04:34 AM
