Old 03-08-2015, 07:30 PM   #323
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Originally Posted by HiHoAgRV View Post
If you don't want anyone to see a flawed bellypan, just tell them that you have a leaky black tank and it tends to dribble from the pans various perfect seams. They will take your word that it's perfect...
Great idea... Much less violent than mine. I recommend keeping mine as a backup, just in case they insist...
Hope you get back on the project soon.
-Red, tee 'em up...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 03-19-2015, 12:12 PM   #324
1989 34.5' Airstream 345
Ebro , Fla Panhandle
So Shelly. I mean Dena. :-). Seems you have had a little time away from your project, if not totally lost in the clouds Are your savings and spirits rising for the next round of belly pan challenges?
Once this is done and behind you, you will be stronger and even better equipped to carry on with the rest of your GT 20 restoration.
If your spirits need even more of a lift, perhaps you would consider joining me as navigator aboard my 345 Moho for a cruise in mid April from Az up to Colorado for the airstream motorhome gathering. I would enjoy the company, and there may be a vintage trailer group joining us there in Colo. Springs. Could be some inspiration there.
And most likely lots of blue skies to further lift the spirits
PM. Me if you would like to discuss details.
At any rate I and others here are standing by for updates when your winter project is back under way. And looking forward to seeing you getting the shell back on your refreshed chassis.
Cheers Richard
tevake is offline   Reply With Quote
Old 03-27-2015, 08:03 PM   #325
GlamperGirl
'65 GT 20' my winter project
Well I have been to NYC twice, DC twice and Vegas once in my first four weeks of my new job at Equinix.
Today I was able to find time to pick up the banana wraps from Dreamers Rods and Pickups . If you remember they were a mess. Big dents as you see in the before.
Tomorrow my friend Larry that lives far away is going to help me finish the belly pan. Hope we flip the chassis! Click image for larger version
Name:	ImageUploadedByAirstream Forums1427508114.817371.jpg
ID:	235052Click image for larger version
Name:	ImageUploadedByAirstream Forums1427508129.650090.jpg
Missing you all and the work on the airstream. Dena
thumbelinadj is offline   Reply With Quote
Old 03-28-2015, 05:09 AM   #326
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Glad to hear from you. Our "day jobs" sure get in the way of our Airstream projects! Traveling is like working 24 hour days. But I plan on leaving my winter gig soon and I can get the 86 ready for a spring time Airstream adventure to the southeast. Your time will come.
I hope you can get those pretty banana wraps mounted and the belly pan nailed down this weekend. A pretty full plate if you ask me. I'll be down in my rented garage this weekend pushing my polisher around. I have about 120 hours in it and still counting. Mindless, boring work. No wonder it is expensive to subcontract.
Have fun...
David
Old 03-29-2015, 01:18 AM   #327
GlamperGirl
After Undoing some work, we dry fit the banana wraps. I learned the method of the buck rivet to attach the banana wraps. This is dry fit. What a day! I miss the shop oh so much. Click image for larger version
Name:	ImageUploadedByAirstream Forums1427613444.269125.jpg
Name:	ImageUploadedByAirstream Forums1427613459.851473.jpg
Old 03-29-2015, 05:46 AM   #328
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I have never hammered a rivet against a bucking bar. I've seen it done at Jackson Center and understand the concept. I've seen old movies where construction workers are riveting together some big bridge girders and using air or steam powered hammers to bang hot steel rivets tight. But I've never done it. One of these days! Solid bucked rivets are the strongest, and the cheapest rivet. Olympic "tri-fold" rivets are on the opposite side as weaker and expensive.
It is such fun and satisfying work to build something with your own two hands. A vintage Airstream rebuild is a classic example of doing it all. Planning, material selection, cut and fit and finish assembly. Mechanical, plumbing, electrical, carpentry. There are major highs and lows of such a large project. I have a good friend who farms, built his own house and machine shed, restores old sports cars, and is a licensed mechanical engineer. We have a saying in Iowa: "Don't judge a person by what they have, judge them by what they don't need." It is very satisfying doing it yourself!
You are close to flipping your frame sunny side up. Maybe in a weekend or two.
David
Old 03-29-2015, 09:36 AM   #329
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
David
Why don't you just swing by my place and I'll show you how to buck rivets. Colorado isn't that far away
Old 03-29-2015, 10:03 AM   #330
GlamperGirl
I'll be right over on my gulfstream! Actually I will send it you, pick you up and chain you to the carlift until you finish all the work I need done
Old 03-29-2015, 03:10 PM   #331
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Aerowood on the Airstream chain gang! Thumbelina would put a bowl of swill and water out for you now and then, as well as a box of solid rivets.
David
Old 03-29-2015, 04:49 PM   #332
Aerowood's Avatar
Arvada , Colorado
So sorry, I don't do house calls Dena
Old 03-29-2015, 05:14 PM   #333
1970 27' Overlander
1970 21' Globetrotter
Hamilton , Montana
Thumbelinadj pick me up on your way to Aerowoods.
gdod25 is offline   Reply With Quote
Old 03-29-2015, 07:35 PM   #334
GlamperGirl
Will do!
Old 04-05-2015, 10:09 AM   #335
GlamperGirl
Good Morning! Video time lapse of the work I have been doing here. My friend took the SD card and put this together last night.
Old 04-05-2015, 06:02 PM   #336
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Holy cow thumbelina! Great video. You will give folks the impression there is nothing to this Airstream renovation thing.
So when do you plan to marry the shell to the new frame?
David
1963 Globe Trotter Winter Project Chrjbenn 1960 - 1964 Globetrotter 15 05-28-2013 05:23 AM
1968 Airstream Sovereign - Needs restoration - Great winter project! eBay Watch Airstreams on eBay 0 10-02-2011 04:30 PM
Winter project time toastie Electrical - Systems, Generators, Batteries & Solar 3 11-03-2006 04:34 AM
