Old 02-19-2015, 07:36 PM   #253
GlamperGirl
I love Kip for making me a better hobbyist. So question tonight is I about wheel wells. There were two layers.
New ones are back. Higher gauge and lovely for $85 each.
Why do I need that second plastic layer?
Name:	ImageUploadedByAirstream Forums1424399771.320014.jpg
ID:	232736Click image for larger version
Name:	ImageUploadedByAirstream Forums1424399781.688633.jpg
ID:	232737Click image for larger version
Name:	ImageUploadedByAirstream Forums1424399792.721001.jpg
thumbelinadj is offline   Reply With Quote
Old 02-19-2015, 07:38 PM   #254
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Originally Posted by rmkrum View Post
Can you give us details about the tools needed? Pictures?
They're pictures in my 71 Globetrotter full monte thread below
Aerowood is online now   Reply With Quote
Old 02-19-2015, 07:42 PM   #255
Aerowood's Avatar
Arvada , Colorado
The plastic layer covered the insulation that was installed over the metal well wells
Old 02-19-2015, 07:54 PM   #256
indy's Avatar
1962 22' Safari
kansas city , Missouri
Images: 22
The added layer of plastic /fiberglass adds a small level of sound and thermo insulation, they come up into the living space, under cabinets sure but think, how if only the metal is there = 0 insulation and how much is in floor just my opinion.
indy is offline   Reply With Quote
Old 02-19-2015, 08:06 PM   #257
indy's Avatar
1962 22' Safari
Images: 22
If you can afford to add your own better insulation to the inside I would add something. In my case I could not gain much hight under the bed, so I added 1/4" pink siding insulation.
Old 02-19-2015, 08:34 PM   #258
GlamperGirl
I totally forgot about the insulation. I can figure this out!
Ok good!
My other hero is PBearSailor. Steve did a lot of fiberglass and much better than me.
I have double sided MDO down except on one piece that you will see in gray. It's plywood.
All by myself ---thank you ---- Click image for larger version
Name:	ImageUploadedByAirstream Forums1424403028.076007.jpg
ID:	232739I made a mess. But I protected everything and got the fiberglass fabric down with epoxy. Trimmed pieces off and places them near the kegerator designated space. Formerly the gaucho space.
Covered the shower area, water tank and entry with the fabric. Then used the four inch tape on seams.
Filled in spaces
Name:	ImageUploadedByAirstream Forums1424403219.551725.jpg
Name:	ImageUploadedByAirstream Forums1424403103.423120.jpg
ID:	232740Click image for larger version
Name:	ImageUploadedByAirstream Forums1424403144.110879.jpg
ID:	232741Click image for larger version
Name:	ImageUploadedByAirstream Forums1424403158.925861.jpg
Old 02-19-2015, 09:15 PM   #259
Central , Mississippi
I guess I look at the bellypan from a different perspective, it's easy to install a 3/16 big head rivet, it's easy to drill it out and just as easy to put another one in its place.
Minimal chance of it unthreading and I'm not planning on working inside the bellypan any time soon.
I vote for rivets.
The floor is AWESUM!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-19-2015, 10:35 PM   #260
(-1 Rivet_
REDSLED88's Avatar
1965 20' Globetrotter
Jackson , California
True, 3/16" rivets are easy to install and remove.
I agree, floors awesome!
Oh yeah, and I think I used a 12# shotput for my banana wraps, a fairly bigger one anyways.
TIMK
Thanks in advance!
TAC CA-77
REDSLED88 is offline   Reply With Quote
Old 02-20-2015, 05:30 AM   #261
flygrrl
flygrrl's Avatar
1962 19' Globetrotter
Winchester , Ontario
Dena, you are doing an AWESOME job, my heroine! Grrls rock.
Leonie
TV: 2007 Jeep GC Laredo diesel
Toy: 1995 Jeep YJ
Experience is what you get from not having it when you needed it.
flygrrl is offline   Reply With Quote
Old 02-20-2015, 06:49 AM   #262
1989 34.5' Airstream 345
Ebro , Fla Panhandle
^^. I'll second that, great progress. The floor coating looks good!
The idea of having smaller access panels in strategic areas of the pan sure makes good sense.
Don't know about the extra flat bar over the seams. Are the edges of your old panels torn up badly? Are you thinking of bedding them to provide extra sealing at the seams? Thinking of using them just at the edges of the access panels?
I'm just not sure what is meant to be gained with them?
Are the overlaps of the panels oriented so the seams open towards the back of the trailer?
Pardon all the questions, motorhomes don't have underfloor pans, So I am trying to getting up to speed on this part of the trailer. Is the goal to make the the pan skin water tight? Are there drains?
You have a good pace going, and your logistic planner seems on top of getting parts and material and having them on hand :-)
Hope you have time before your coming out party ( out of the shop that is)to go over the roof to assure no leaks once back out in the weather.
Carry on, you and your team are going to make it and some.
Oh, Any chance of having someone doing sanding and finish work on the cabinetry while it is sitting out? Will it be back inside the trailer once you are out of the shop?
So many considerations, as if you don't all ready have enough to think about.
Don't let me distract you.
Cheers Richard
tevake is offline   Reply With Quote
Old 02-20-2015, 10:04 AM   #263
GlamperGirl
Old panels are toast.
Old 02-21-2015, 01:47 PM   #264
GlamperGirl
'65 GT 20' my winter project
I made a bad mistake that I hope we figured out. Click image for larger version
Name:	ImageUploadedByAirstream Forums1424551645.891795.jpg
Attached the floor and forgot about under mount. Size wise it's not an issue. Stupid of me
With that said mounted the wheel wells above. Ugh. I'm feeling sick about it.
Old 02-22-2015, 10:52 AM   #265
Hey Dena, mistakes happen.
I often feel well equipped to do a project once it's finished, that's the challenge of doing things for the first time.
Is the problem that the wheel well should be mounted from the bottom side?
If so, why not pull them off and remount them correctly.
5200 is slow to dry especially if not in contact with air. They may still come off
W O. Too much difficulties (some mess for sure) Maybe some heat on the flange could help separate them from the floor.
Or you can get into the wheel well and glass the exposed ply edge lapping onto the metal of the wheel well.
They make mistakes at the factory too.
Just solve the problem and move forward.
You have good momentum going, don't let this bog you down.
Cheers Richard
Old 02-22-2015, 06:06 PM   #266
GlamperGirl
The belly pan work has stolen my soul. None of the workers from the last stage will be able to get to this next level. I am looking for all new workers to help me finish. Have found a few good prospects.
I am so mad about the wheel wells. It's my fault I just missed the step. I can't tear all that work up again and mount them below.
Dejected Dena today
1963 Globe Trotter Winter Project Chrjbenn 1960 - 1964 Globetrotter 15 05-28-2013 05:23 AM
1968 Airstream Sovereign - Needs restoration - Great winter project! eBay Watch Airstreams on eBay 0 10-02-2011 04:30 PM
Winter project time toastie Electrical - Systems, Generators, Batteries & Solar 3 11-03-2006 04:34 AM
